Ansible Task for Importing PKI files
I’m using a playbook to configure a 1.4.0 VyOS and struggling to find an efficient solution for importing PKI files. As some of you will know, if you run import pki... from operational mode, it outputs the set pki... command equivalent for you to use in config mode. Whereas if you issue run import pki... from config mode, it imports the file directly.
Now, because the vyos.vyos.vyos_config module doesn’t support using the run <command> syntax, I have a workaround that uses the vyos.vyos_command module to issue the import command in op mode, then takes the resulting stdout and applies regex to format it appropriately, then passes it to vyos.vyos_config to apply the commands.
This seems unnecessarily complicated, and for a sanity check, I just wanted to post here and make sure that I’m not missing any info regarding a simpler solution. Let me know if you have any thoughts, and thanks for your time. Btw, I’m running the latest version of the collection (6.0.0).
Here’s the playbook for anyone interested:
- name: Generate and install PKI files
  hosts: vyos
  connection: network_cli
  gather_facts: no
  tasks:
    - name: Run import commands in operational mode to get set commands
      vyos.vyos.vyos_command:
        commands:
          - "{{ item.cmd_dict }}"
      loop:
        - cmd_dict: "import pki ca vyos-ca file /config/auth/vyos-ca.crt"
        - cmd_dict:
            command: "import pki ca vyos-ca key-file /config/auth/vyos-ca.key"
            prompt: "Enter private key passphrase:"
            answer: "\r"
        - cmd_dict: "import pki certificate vyos-cert file /config/auth/vyos-cert.crt"
        - cmd_dict:
            command: "import pki certificate vyos-cert key-file /config/auth/vyos-cert.key"
            answer: "\r"
      register: import_results
      ignore_errors: true
    - name: Extract set commands from output
      set_fact:
        set_commands: "{{ set_commands | default([]) + [item.stdout_lines | flatten | select('match', '^set ') | first | default('')] }}"
      loop: "{{ import_results.results }}"
      when: item.stdout_lines is defined
    - name: Debug extracted set commands
      debug:
        var: set_commands
    - name: Apply set commands in config mode
      vyos.vyos.vyos_config:
        lines:
          - "{{ item }}"
        comment: "Imported PKI for {{ item.split()[3] }} via Ansible"
        save: true
        match: none
      loop: "{{ set_commands }}"
      when: item | length > 0
This is not Vyatta, this is VyOS :slight_smile: Rename all your playbooks and forget about Vyatta.
Done. Thanks for the correction.
We do ours with templates and ansible lookup to lookup the file on the ansible controller.
task.yml
- name: "Assert PKI certificates"
  vyos_config:
    lines: "{{ lookup('template', 'templates/pki.cfg') }}"
  notify: Save config
pki.cfg
set pki ca 'root_ca' certificate '{{ lookup('ansible.builtin.file', './files/ca.pem' | split('\n')[1:-1] | join('') }}'
something like that would work also
Thanks for this, I’ll test it out.
