Hello guys,
I have done some wrong configuration and now is not ok sompting is wrong on ripe…etc
I have 2 ISPs , 1 IPS AS: 870X and 2nd IPS AS: 666X
Ower as number AS: 3391X
I have this rule on the config
set policy prefix-list IPv4-870X-OUT rule 100 action ‘permit’
set policy prefix-list IPv4-870X-OUT rule 100 description ‘AS3391X’
set policy prefix-list IPv4-870X-OUT rule 100 prefix ‘77.81.XXX.0/24’
set policy prefix-list IPv4-666X-OUT rule 100 action ‘permit’
set policy prefix-list IPv4-666X-OUT rule 100 description ‘AS3391X’
set policy prefix-list IPv4-666X-OUT rule 100 prefix ‘77.81.XXX.0/24’
set policy route-map IPv4-NET-666X rule 100 action ‘permit’
set policy route-map IPv4-NET-666X rule 100 match ip address prefix-list ‘IPv4-666X-OUT’
set policy route-map IPv4-NET-870X rule 100 action ‘permit’
set policy route-map IPv4-NET-870X rule 100 match ip address prefix-list ‘IPv4-870X-OUT’
and i setup this
set policy route-map IPv4-NET-870X rule 100 set as-path-prepend 666X
I whanted the routes/traffic to be prefered/prioritize on the ISP AS: 666X
Cuz on ISP AS: 666X we have ddos solution from them, we had an ddos so i setup as-path-prepend
I left it like this for 5 days and after i deleted the rule yerstaday
delete policy route-map IPv4-NET-870X rule 100 set
commit, save…etc
Today the traffic on ripe was showing like ISP 870X is not there any more, even on ipinfo.io the secand isp is missing, on Twelve99 Looking Glass is missing parts, ISP, route …etc so i made like this today thinking is sompting wrong and i have to set back ower as to the ip range.
set policy route-map IPv4-NET-870X rule 100 set as-path-prepend 3391X
commit…save…etc
After 30 minutes i deleted the rule
Now on Twelve99 Looking Glass it shows 2 times ower AS, like:
BGP routing table entry for 77.81.XX.0/24
Last Modified: May 9 14:33:55.203 for 01:25:35
Paths: (7 available, best #1)
Path #1: Received by speaker 0
870X 3391X 3391X
I know before i made this “prepend” was
870X 3391X
On RIPE, on the ip range it should show ISP as number both but now it shows ower AS Number.
Is there a way to reverse all this and to e back to normal like was before i used path-prepend ?
If someone is ready to help even for $ it will be my pleasure to pay just to fix this.
Thank you
