Available system optimizations?
I found this document but I think it can get improved:
In my case Im at 1.4 rolling so perhaps thats why some commands differs?
  1. Network card and driver optimization:
It mentions using ethtool to set the ring-buffers but today one can do this through configuration:
set interfaces ethernet eth0 ring-buffer rx 4096
set interfaces ethernet eth0 ring-buffer tx 4096
  1. SMP Affinity.
The commands mentioned here for example:
set interfaces ethernet eth0 smp_affinity 1
set interfaces ethernet eth1 smp_affinity 2
doesnt exist at all in version VyOS 1.4-rolling-202307060317 or am I missing something here?
Followup to above is that perhaps various interface offload settings should be mentioned?
Such as:
set interfaces ethernet eth0 offload lro
set interfaces ethernet eth0 offload rfs
set interfaces ethernet eth0 offload rps
And the system option performance:
set system option performance throughput
or:
set system option performance latency
as described in:
Other than that whats your experience of needed optimizations (compare to default) to make VyOS work better/faster?
Maybe not completely tuning… but needed when using an i40e card like the Intel XL710. In the /config/scripts/vyos/vyos-preconfig-bootup.script
for f in /sys/class/net/*; do
    dev=$(basename $f)
    driver=$(readlink $f/device/driver/module)
    if [[ -n $driver ]] && [[ x"$(basename $driver)" -eq x"i40e" ]]; then
        ethtool --set-priv-flags $dev disable-source-pruning on
        ethtool --set-priv-flags $dev disable-fw-lldp on
        ethtool -C $dev adaptive-rx off adaptive-tx off
    fi
done
Out of the blue that sounds like something that should already be included by default in vyos-preconfig-bootup.script?
You don’t need any tunning as you don’t have any bottlenecks.
So it depends
