I can’t a get a bandwidth test to run between an EdgeRouter and a vyos machine and between two Vyos machines.
Confirmed no firewall enabled on the interface in Proxmox. No firewall on the LAN router. No firewall configuration in Vyos whatsoever.
When testing from a Vyos VM, it just is “stuck” trying to get started. When testing from the EdgeRouter, the edgerouter immediately reports connection refused. Ideas
Hi @Sassriverrat, what is the bandwidth test are you doing? Is it iperf/iperf3
Can you see ICMP reachability from VyOS VM to EdgeRouter?
Try to monitor traffic on VyOS VM when you begin bandwidth test from EdgeRouter
So using bandwidth-test in vyos is not working for you? Can you provide vyos version? From vyos side, did you try both initiating and/or accepting connections?
monitor bandwidth-test initiate x.x.x.x
# or
monitor bandwidth-test accept
