On first setup BFD is working fine, after restart router it`s get bugged and after restart frr bfdd (restart frr bfdd) it’s get fixed
Version: VyOS 1.3-beta-202107062242
Release Train: equuleus
Built by: [email protected]
Built on: Thu 08 Jul 2021 03:42 UTC
Build UUID: a03bb23d-a59c-4a22-bcda-2126670bb565
Build Commit ID: 62985f00fb4c3b
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: 5bc08e20-165d-4481-94ac-607e30117f81
set protocols bfd peer 10.0.1.100 interval multiplier '3'
set protocols bfd peer 10.0.1.100 interval receive '50'
set protocols bfd peer 10.0.1.100 interval transmit '100'
set protocols bfd peer 10.0.1.100 multihop
set protocols bfd peer 10.0.1.100 source address '10.0.1.3'
set protocols bfd peer 10.0.3.10 interval multiplier '3'
set protocols bfd peer 10.0.3.10 interval receive '50'
set protocols bfd peer 10.0.3.10 interval transmit '100'
set protocols bfd peer 10.0.3.10 multihop
set protocols bfd peer 10.0.3.10 source address '10.0.3.3'
set protocols bgp 65000 neighbor 10.0.1.100 bfd
set protocols bgp 65000 neighbor 10.0.3.10 bfd
First apply config or restart frr bfdd (expected result)
[email protected]:~$ show protocols bfd peers
Session count: 2
SessionId LocalAddress PeerAddress Status
1624361981 10.0.3.3 10.0.3.10 down
2347419227 10.0.1.3 10.0.1.100 up
After router reboot
Session count: 3
2216489611 10.0.1.3 10.0.1.100 up
417126398 10.0.3.3 10.0.3.10 up
2986967380 10.0.3.3 10.0.3.10 init
SessionId 417126398 and 2986967380 both are still flapping in down, up, init state
On server 10.0.3.10 bird:
Jul 11 13:44:01 storage1 bird[42831]: bfd1: Bad packet from 10.0.3.3 - unknown session id (2824758721)
Jul 11 13:44:02 storage1 bird[42831]: 65000-10.0.3.3: State changed to stop
Jul 11 13:44:02 storage1 bird[42831]: 65000-10.0.3.3: State changed to down
Jul 11 13:44:02 storage1 bird[42831]: 65000-10.0.3.3: Starting
Jul 11 13:44:02 storage1 bird[42831]: 65000-10.0.3.3: State changed to start
Jul 11 13:44:02 storage1 bird[42831]: bfd1: Bad packet from 10.0.3.3 - unknown session id (2020787167)
Weirdly this is just happening on 10.0.3.10 but bird configuration is almost same (diffrent AS, neighbor IP etc…). 10.0.3.10 is directly connected to router (router is VM, 3.10 also), 1.100 is connected via wireguard VPN
Bird config:
router id 10.0.3.10;
filter export_bgp {
if ( (ifname ~ "ens*") ) then {
if net != 0.0.0.0/0 then accept;
reject;
# Configure synchronization between BIRD's routing tables and the
# kernel.
protocol kernel {
learn; # Learn all alien routes from the kernel
persist; # Don't remove routes on bird shutdown
merge paths on;
scan time 2; # Scan kernel routing table every 2 seconds
import none;
graceful restart;
export all; # Default is export none
# Watch interface up/down events.
protocol device {
debug { states, routes, filters };
scan time 2; # Scan interfaces every 2 seconds
protocol direct {
debug all;
interface "ens*";
template bgp vyos {
local as 65401;
debug { states, routes, filters, interfaces };
multihop;
gateway recursive;
import all;
export filter export_bgp;
add paths on;
graceful restart;
# Peer with route reflector.
protocol bgp '65000-10.0.3.3' from vyos {
neighbor 10.0.3.3 as 65000;
source address 10.0.3.10; # The local address we use for the TCP connection
bfd on;
protocol bfd {
interface "ens*" {
multiplier 3;
interval 50 ms;
idle tx interval 100 ms;
