I’m working on BGP LAB, to get VCNE :
My actual config :
As you can see Between VyOS2 & 1 this is a OSPF area “0”
From Vy-1 i can reach PC&1 in LAN 10.0.0.1
So now i need to configure BGP “eBGP” on Vy-1 & Vy-3
BGP STATUS :
Vy-3 ROUTE TABLE :
Vy-1 ROUTE TABLE :
I don’t understand how to get route on Vy-3 to reach LAN 10.0.0.0/24
Config after so many test :
Vy-1 :
address 192.168.1.1/24
description WAN-OSPF
hw-id 0c:a4:ec:2b:ce:00
hw-id 0c:a4:ec:2b:ce:01
ethernet eth2 {
hw-id 0c:a4:ec:2b:ce:02
ethernet eth3 {
address 88.88.88.1/16
hw-id 0c:a4:ec:2b:ce:03
loopback lo {
address 10.1.1.1/32
policy {
prefix-list AS65535-IN {
rule 10 {
action permit
prefix 192.168.0.0/16
prefix-list AS65535-OUT {
rule 10 {
action permit
route-map AS65535-IN {
rule 10 {
action permit
match {
ip {
address {
route-map AS65535-OUT {
rule 10 {
action permit
match {
ip {
address {
route-map CONNECT {
rule 10 {
action permit
match {
interface eth0
protocols {
bgp 65534 {
address-family {
ipv4-unicast {
network 10.1.1.1/32 {
neighbor 88.88.88.2 {
address-family {
ipv4-unicast {
route-map {
export AS65535-OUT
import AS65535-IN
ebgp-multihop 2
remote-as 65535
update-source 88.88.88.1
parameters {
router-id 88.88.88.1
Vy-3
Interfaces {
address 88.88.88.2/16
hw-id 0c:a4:ec:b3:1c:00
hw-id 0c:a4:ec:b3:1c:01
ethernet eth2 {
hw-id 0c:a4:ec:b3:1c:02
ethernet eth3 {
hw-id 0c:a4:ec:b3:1c:03
loopback lo {
address 10.2.2.2/32
policy {
rule 10 {
action permit
prefix 88.88.0.0/16
rule 10 {
action permit
prefix 88.88.0.0/16
rule 10 {
action permit
match {
ip {
address {
rule 10 {
action permit
match {
ip {
address {
protocols {
bgp 65535 {
address-family {
ipv4-unicast {
network 10.2.2.2/32 {
neighbor 88.88.88.1 {
address-family {
ipv4-unicast {
route-map {
export AS65535-OUT
import AS65535-IN
ebgp-multihop 2
remote-as 65534
update-source 88.88.88.2
parameters {
router-id 88.88.88.2
static {
route 10.2.2.2/32 {
blackhole {
distance 254
Thanks in advance.
Jeff
2
Since you use 2 routing protocols, OSPF and BGP, did you enable redistribution of OSPF in BGP and of BGP in OSPF on Vy1?
(you should put the entire configuration of each router)
olofl
3
vyos-1 is not redistributing 10.0.0.0/24.
your prefix lists doesn’t match 10.0.0.0/24.
Hi Jeff, hi olofl
Thanks for your quick reply so :
Config belongs,
Rule 11 about olofl
Vy-1
ethernet eth2 {
ethernet eth3 {
loopback lo {
address 10.1.1.1/32
policy {
rule 10 {
action permit
rule 11 {
** action permit**
** prefix 10.0.0.0/24**
rule 10 {
action permit
rule 11 {
** action permit**
rule 10 {
action permit
match {
ip {
address {
rule 10 {
action permit
match {
ip {
address {
route-map CONNECT {
rule 10 {
action permit
match {
interface eth0
protocols {
bgp 65534 {
address-family {
ipv4-unicast {
address-family {
ipv4-unicast {
route-map {
export AS65535-OUT
import AS65535-IN
ebgp-multihop 2
remote-as 65535
parameters {
ospf {
area 0 {
network 192.168.1.0/24
default-information {
originate {
always
metric 10
metric-type 2
log-adjacency-changes {
parameters {
abr-type cisco
router-id 192.168.1.1
redistribute {
connected {
metric-type 2
route-map CONNECT
static {
route 10.1.1.1/32 {
blackhole {
distance 254
Vy-3
ethernet eth2 {
ethernet eth3 {
loopback lo {
address 10.2.2.2/32
policy {
rule 10 {
action permit
prefix 88.88.0.0/16
rule 10 {
action permit
prefix 88.88.0.0/16
rule 10 {
action permit
match {
ip {
address {
rule 10 {
action permit
match {
ip {
address {
protocols {
bgp 65535 {
address-family {
ipv4-unicast {
address-family {
ipv4-unicast {
route-map {
export AS65535-OUT
import AS65535-IN
ebgp-multihop 2
remote-as 65534
parameters {
static {
route 10.2.2.2/32 {
blackhole {
distance 254
Vy-2
address 192.168.1.2/24
hw-id 0c:a4:ec:27:f6:00
address 10.0.0.1/24
description LAN-1
hw-id 0c:a4:ec:27:f6:01
ethernet eth2 {
hw-id 0c:a4:ec:27:f6:02
ethernet eth3 {
hw-id 0c:a4:ec:27:f6:03
loopback lo {
policy {
route-map CONNECT {
rule 10 {
action permit
match {
interface eth0
rule 11 {
action permit
match {
interface eth1
protocols {
ospf {
area 0 {
parameters {
abr-type cisco
router-id 192.168.1.2
redistribute {
connected {
metric-type 2
route-map CONNECT
service {
dhcp-server {
shared-network-name DHCP {
authoritative
subnet 10.0.0.0/24 {
default-router 10.0.0.1
dns-server 10.0.0.1
lease 86400
range 0 {
start 10.0.0.10
stop 10.0.0.20
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 115200
host-name vyos
login {
user vyos {
authentication {
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
syslog {
global {
facility all {
level info
facility protocols {
level debug
den
6
You are filtering 10.0.0.0/24 on Vy-3 side.
On Vy-3 you need to add
set policy prefix-list AS65535-IN rule 20 action permit
set policy prefix-list AS65535-IN rule 20 prefix 10.0.0.0/24
into AS65535-IN prefix-list
den
7
And btw - you need to do
set protocols bgp 65534 address-family ipv4-unicast redistribute ospf route-map AS65535-OUT
on Vy-1 because export AS65535-OUT it is not redistribution, it is only filtering on outgoing way.
Hello Den,
Thanks for your reply.i check
system
Closed
9
