Is BGP FlowSpec supported/planned for the next release?
As workaround (I don’t this if possible) could be to use ExaBGP on an external machine to inject flow-spec in the BGP.
My biggest question is: is VyOS BGP able to transmit flow-spec or must be used a flow-spec aware BGP
i guess since VyOS use quagga it don´t support flow-spec
can you submit a question on phabricator so maybe we can bring some devs to discuss this in public
Thanks!
Done.
