Hi Team,
Pertaining to my other thread; I am facing this issue with BGP and Azure tunnel. I have attached my diagram herewith and my setup is as below.
I have vyos 1.2.8 and two ISPs terminated on it -
1.2.3.4 with VTI2 (169.254.21.9)
5.6.7.8 with VTI4 (169.254.21.13)
So now I have tunnels configured with Azure
1.2.3.4 [169.254.21.9] <==> 9.9.10.10[169.254.21.1]
5.6.7.8 [169.254.21.13] <==> 7.7.7.7 [169.254.22.1]
My local AS is 65506 and remote AS is 65515
My Vyos Subnet is 192.168.40.0/23
And Remote subnet is 10.11.44.0/22
Now issue what we noticed here is - from vyos end I advertised 192.168.40.0/23
set protocols bgp 65506 address-family ipv4-unicast network 192.168.40.0/23
However when I see routes advertised from Azure end or received routes
show ip bgp neighbors 169.254.21.1 received-routes
Default local pref 100, local AS 65506
Nexthop codes: @NNN nexthop's vrf id, < announce-nh-self
*> 10.1.0.0/16 169.254.21.1 0 65515 i
***> 10.11.44.0/22 169.254.21.1 0 65515 i**
While for other Peer
show ip bgp neighbors 169.254.22.1 received-routes
*> 10.1.0.0/16 169.254.22.1 0 65515 i
*> 10.11.44.0/22 169.254.22.1 0 65515 65515 65515 65515 i
*> 192.168.40.0/23 169.254.22.1 0 0 65515 65506 i
If notice here 192.168.40.0/23 which is my subnet getting advertised by Azure and is sending it to me. Even If I look at the path its been received via 65515 which is Azure and then mine. This is pretty surprising and Azure if receiving with igp.
Hence wanted to know even if I am advertising the routes in Global BGP; how can I ensure that routes are being advertised to both my neighbors?
And if not how would I advertise with specific neighbor like cisco?
Hence my issue is if 169.254.21.1 goes down my traffic stops completely and I suspect is; since 192.168.40.0/23 is being learned from azure; Azure it not sending the traffic back.
Can someone please help me on this issue?
