Hi Team,
In my below scenario both my tunnels are up
vyos@R4# run show vpn ipsec sa
Peer ID / IP Local ID / IP
100.1.1.60 100.1.1.50
Tunnel State Bytes Out/In Encrypt Hash NAT-T A-Time L-Time Proto
vti up 205.0K/14.3K aes256 sha256 no 2146 3600 all
200.1.1.60 200.1.1.50
vti up 13.8K/198.0K aes256 sha256 no 2021 3600 all
And BGP is being learned from both the interfaces
vyos@R4# run show ip bgp
BGP table version is 0, local router ID is 192.168.5.50
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, R Removed
*> 10.10.11.0/24 169.254.254.11 1 0 65002 i
* 169.254.252.11 1 0 65002 i
*> 192.168.47.0 0.0.0.0 1 32768 i
Total number of prefixes 2
Here are my interfaces
vyos@R4# run show interfaces
eth0 192.168.47.50/24 u/u
eth1 200.1.1.50/24 u/u
eth2 100.1.1.50/24 u/u
eth3 192.168.5.50/24 u/u
lo 127.0.0.1/8 u/u
::1/128
vti5 169.254.254.10/32 u/u
vti10 169.254.252.10/32 u/u
Now my ping from 192.168.47.128 to 10.10.11.129 works fine through link 1 or through 169.254.254.10
however if I shut eth2 [100.1.1.50] even though bgp show
vyos@R4# set interfaces ethernet eth2 disable
vyos@R4# commit
* 10.10.11.0/24 169.254.252.11 1 0 65002 i
My ping never comes up
Tunnel even shows properly
vyos@R5# run show vpn ipsec sa
100.1.1.50 100.1.1.60
vti down n/a n/a n/a no 0 3600 all
200.1.1.50 200.1.1.60
vti up 229.2K/19.5K aes256 sha256 no 1887 3600 all
Any clue why?
vyos@R4# run show ip bgp neighbors 169.254.252.11
BGP neighbor is 169.254.252.11, remote AS 65002, local AS 65001, external link
BGP version 4, remote router ID 192.168.5.51
BGP state = Established, up for 00:38:43
Last read 22:15:58, hold time is 30, keepalive interval is 10 seconds
Configured hold time is 30, keepalive interval is 10 seconds
Neighbor capabilities:
4 Byte AS: advertised and received
Route refresh: advertised and received(old & new)
Address family IPv4 Unicast: advertised and received
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 20 0
Notifications: 0 9
Updates: 5 3
Keepalives: 233 232
Route Refresh: 0 0
Capability: 0 0
Total: 258 244
Minimum time between advertisement runs is 30 seconds
Update source is 169.254.252.10
For address family: IPv4 Unicast
Community attribute sent to this neighbor(both)
0 accepted prefixes
Connections established 1; dropped 0
Last reset never
Local host: 169.254.252.10, Local port: 179
Foreign host: 169.254.252.11, Foreign port: 34037
Nexthop: 169.254.252.10
Nexthop global: ::
Nexthop local: ::
BGP connection: non shared network
Read thread: on Write thread: off
I can even reach 169.254.252.11 from R4
vyos@R4# ping 169.254.252.11
PING 169.254.252.11 (169.254.252.11) 56(84) bytes of data.
64 bytes from 169.254.252.11: icmp_req=1 ttl=64 time=0.407 ms
64 bytes from 169.254.252.11: icmp_req=2 ttl=64 time=0.435 ms
^C
--- 169.254.252.11 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 0.407/0.421/0.435/0.014 ms
Here is my entire config for R4
set interfaces ethernet eth0 address '192.168.47.50/24'
set interfaces ethernet eth0 hw-id '00:0c:29:ef:bb:2c'
set interfaces ethernet eth1 address '200.1.1.50/24'
set interfaces ethernet eth1 hw-id '00:0c:29:ef:bb:36'
set interfaces ethernet eth2 address '100.1.1.50/24'
set interfaces ethernet eth2 'disable'
set interfaces ethernet eth2 hw-id '00:0c:29:ef:bb:40'
set interfaces ethernet eth3 address '192.168.5.50/24'
set interfaces ethernet eth3 hw-id '00:0c:29:ef:bb:4a'
set interfaces loopback 'lo'
set interfaces vti vti5 address '169.254.254.10/32'
set interfaces vti vti10 address '169.254.252.10/32'
set protocols bgp 65001 neighbor 169.254.252.11 'disable-connected-check'
set protocols bgp 65001 neighbor 169.254.252.11 ebgp-multihop '10'
set protocols bgp 65001 neighbor 169.254.252.11 remote-as '65002'
set protocols bgp 65001 neighbor 169.254.252.11 timers holdtime '30'
set protocols bgp 65001 neighbor 169.254.252.11 timers keepalive '10'
set protocols bgp 65001 neighbor 169.254.252.11 update-source '169.254.252.10'
set protocols bgp 65001 neighbor 169.254.254.11 'disable-connected-check'
set protocols bgp 65001 neighbor 169.254.254.11 ebgp-multihop '10'
set protocols bgp 65001 neighbor 169.254.254.11 remote-as '65002'
set protocols bgp 65001 neighbor 169.254.254.11 timers holdtime '30'
set protocols bgp 65001 neighbor 169.254.254.11 timers keepalive '10'
set protocols bgp 65001 neighbor 169.254.254.11 update-source '169.254.254.10'
set protocols bgp 65001 network '192.168.47.0/24'
set protocols static interface-route 169.254.252.11/32 next-hop-interface 'vti10'
set protocols static interface-route 169.254.254.11/32 next-hop-interface 'vti5'
set service 'ssh'
set system config-management commit-revisions '20'
set system console device ttyS0 speed '9600'
set system host-name 'R4'
set system login user vyos authentication encrypted-password '$1$FNYTiiQ7$JdybrnisWCqxGWgOIbgTx/'
set system login user vyos level 'admin'
set system ntp server '0.pool.ntp.org'
set system ntp server '1.pool.ntp.org'
set system ntp server '2.pool.ntp.org'
set system package repository community components 'main'
set system package repository community distribution 'helium'
set system package repository community url 'http://packages.vyos.net/vyos'
set system syslog global facility all level 'notice'
set vpn ipsec esp-group r4-r5-l1-esp compression 'disable'
set vpn ipsec esp-group r4-r5-l1-esp lifetime '3600'
set vpn ipsec esp-group r4-r5-l1-esp mode 'tunnel'
set vpn ipsec esp-group r4-r5-l1-esp pfs 'enable'
set vpn ipsec esp-group r4-r5-l1-esp proposal 5 encryption 'aes256'
set vpn ipsec esp-group r4-r5-l1-esp proposal 5 hash 'sha256'
set vpn ipsec esp-group r4-r5-l2-esp compression 'disable'
set vpn ipsec esp-group r4-r5-l2-esp lifetime '3600'
set vpn ipsec esp-group r4-r5-l2-esp mode 'tunnel'
set vpn ipsec esp-group r4-r5-l2-esp pfs 'enable'
set vpn ipsec esp-group r4-r5-l2-esp proposal 5 encryption 'aes256'
set vpn ipsec esp-group r4-r5-l2-esp proposal 5 hash 'sha256'
set vpn ipsec ike-group r4-r5-l1-ike dead-peer-detection action 'restart'
set vpn ipsec ike-group r4-r5-l1-ike dead-peer-detection interval '15'
set vpn ipsec ike-group r4-r5-l1-ike dead-peer-detection timeout '30'
set vpn ipsec ike-group r4-r5-l1-ike ikev2-reauth 'no'
set vpn ipsec ike-group r4-r5-l1-ike key-exchange 'ikev1'
set vpn ipsec ike-group r4-r5-l1-ike lifetime '28800'
set vpn ipsec ike-group r4-r5-l1-ike proposal 10 dh-group '2'
set vpn ipsec ike-group r4-r5-l1-ike proposal 10 encryption 'aes256'
set vpn ipsec ike-group r4-r5-l1-ike proposal 10 hash 'sha256'
set vpn ipsec ike-group r4-r5-l2-ike dead-peer-detection action 'restart'
set vpn ipsec ike-group r4-r5-l2-ike dead-peer-detection interval '15'
set vpn ipsec ike-group r4-r5-l2-ike dead-peer-detection timeout '30'
set vpn ipsec ike-group r4-r5-l2-ike ikev2-reauth 'no'
set vpn ipsec ike-group r4-r5-l2-ike key-exchange 'ikev1'
set vpn ipsec ike-group r4-r5-l2-ike lifetime '28800'
set vpn ipsec ike-group r4-r5-l2-ike proposal 10 dh-group '2'
set vpn ipsec ike-group r4-r5-l2-ike proposal 10 encryption 'aes256'
set vpn ipsec ike-group r4-r5-l2-ike proposal 10 hash 'sha256'
set vpn ipsec ipsec-interfaces interface 'eth2'
set vpn ipsec ipsec-interfaces interface 'eth1'
set vpn ipsec site-to-site peer 100.1.1.60 authentication id '100.1.1.50'
set vpn ipsec site-to-site peer 100.1.1.60 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 100.1.1.60 authentication pre-shared-secret 'admin@123'
set vpn ipsec site-to-site peer 100.1.1.60 authentication remote-id '100.1.1.60'
set vpn ipsec site-to-site peer 100.1.1.60 connection-type 'initiate'
set vpn ipsec site-to-site peer 100.1.1.60 ike-group 'r4-r5-l1-ike'
set vpn ipsec site-to-site peer 100.1.1.60 local-address '100.1.1.50'
set vpn ipsec site-to-site peer 100.1.1.60 vti bind 'vti5'
set vpn ipsec site-to-site peer 100.1.1.60 vti esp-group 'r4-r5-l1-esp'
set vpn ipsec site-to-site peer 200.1.1.60 authentication id '200.1.1.50'
set vpn ipsec site-to-site peer 200.1.1.60 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 200.1.1.60 authentication pre-shared-secret 'admin@123'
set vpn ipsec site-to-site peer 200.1.1.60 authentication remote-id '200.1.1.60'
set vpn ipsec site-to-site peer 200.1.1.60 connection-type 'initiate'
set vpn ipsec site-to-site peer 200.1.1.60 ike-group 'r4-r5-l2-ike'
set vpn ipsec site-to-site peer 200.1.1.60 local-address '200.1.1.50'
set vpn ipsec site-to-site peer 200.1.1.60 vti bind 'vti10'
set vpn ipsec site-to-site peer 200.1.1.60 vti esp-group 'r4-r5-l2-esp'
And here is for R5
set interfaces ethernet eth0 address '10.10.11.60/24'
set interfaces ethernet eth0 hw-id '00:0c:29:e3:b7:c7'
set interfaces ethernet eth1 address '100.1.1.60/24'
set interfaces ethernet eth1 hw-id '00:0c:29:e3:b7:d1'
set interfaces ethernet eth2 address '200.1.1.60/24'
set interfaces ethernet eth2 hw-id '00:0c:29:e3:b7:db'
set interfaces ethernet eth3 address '192.168.5.51/24'
set interfaces ethernet eth3 hw-id '00:0c:29:e3:b7:e5'
set interfaces vti vti5 address '169.254.254.11/32'
set interfaces vti vti10 address '169.254.252.11/32'
set protocols bgp 65002 neighbor 169.254.252.10 'disable-connected-check'
set protocols bgp 65002 neighbor 169.254.252.10 ebgp-multihop '10'
set protocols bgp 65002 neighbor 169.254.252.10 remote-as '65001'
set protocols bgp 65002 neighbor 169.254.252.10 timers holdtime '30'
set protocols bgp 65002 neighbor 169.254.252.10 timers keepalive '10'
set protocols bgp 65002 neighbor 169.254.252.10 update-source '169.254.252.11'
set protocols bgp 65002 neighbor 169.254.254.10 'disable-connected-check'
set protocols bgp 65002 neighbor 169.254.254.10 ebgp-multihop '10'
set protocols bgp 65002 neighbor 169.254.254.10 remote-as '65001'
set protocols bgp 65002 neighbor 169.254.254.10 timers holdtime '30'
set protocols bgp 65002 neighbor 169.254.254.10 timers keepalive '10'
set protocols bgp 65002 neighbor 169.254.254.10 update-source '169.254.254.11'
set protocols bgp 65002 network '10.10.11.0/24'
set protocols static interface-route 169.254.252.10/32 next-hop-interface 'vti10'
set protocols static interface-route 169.254.254.10/32 next-hop-interface 'vti5'
set service 'ssh'
set system host-name 'R5'
set system login user vyos authentication encrypted-password '$1$.0aLHoPW$8Ks/gmja3BMyg7cInbBZz.'
set vpn ipsec esp-group r5-r4-l1-esp compression 'disable'
set vpn ipsec esp-group r5-r4-l1-esp lifetime '3600'
set vpn ipsec esp-group r5-r4-l1-esp mode 'tunnel'
set vpn ipsec esp-group r5-r4-l1-esp pfs 'enable'
set vpn ipsec esp-group r5-r4-l1-esp proposal 5 encryption 'aes256'
set vpn ipsec esp-group r5-r4-l1-esp proposal 5 hash 'sha256'
set vpn ipsec esp-group r5-r4-l2-esp compression 'disable'
set vpn ipsec esp-group r5-r4-l2-esp lifetime '3600'
set vpn ipsec esp-group r5-r4-l2-esp mode 'tunnel'
set vpn ipsec esp-group r5-r4-l2-esp pfs 'enable'
set vpn ipsec esp-group r5-r4-l2-esp proposal 5 encryption 'aes256'
set vpn ipsec esp-group r5-r4-l2-esp proposal 5 hash 'sha256'
set vpn ipsec ike-group r5-r4-l1-ike dead-peer-detection action 'restart'
set vpn ipsec ike-group r5-r4-l1-ike dead-peer-detection interval '15'
set vpn ipsec ike-group r5-r4-l1-ike dead-peer-detection timeout '30'
set vpn ipsec ike-group r5-r4-l1-ike ikev2-reauth 'no'
set vpn ipsec ike-group r5-r4-l1-ike key-exchange 'ikev1'
set vpn ipsec ike-group r5-r4-l1-ike lifetime '28800'
set vpn ipsec ike-group r5-r4-l1-ike proposal 5 dh-group '2'
set vpn ipsec ike-group r5-r4-l1-ike proposal 5 encryption 'aes256'
set vpn ipsec ike-group r5-r4-l1-ike proposal 5 hash 'sha256'
set vpn ipsec ike-group r5-r4-l2-ike dead-peer-detection action 'restart'
set vpn ipsec ike-group r5-r4-l2-ike dead-peer-detection interval '15'
set vpn ipsec ike-group r5-r4-l2-ike dead-peer-detection timeout '30'
set vpn ipsec ike-group r5-r4-l2-ike ikev2-reauth 'no'
set vpn ipsec ike-group r5-r4-l2-ike key-exchange 'ikev1'
set vpn ipsec ike-group r5-r4-l2-ike lifetime '28800'
set vpn ipsec ike-group r5-r4-l2-ike proposal 5 dh-group '2'
set vpn ipsec ike-group r5-r4-l2-ike proposal 5 encryption 'aes256'
set vpn ipsec ike-group r5-r4-l2-ike proposal 5 hash 'sha256'
set vpn ipsec site-to-site peer 100.1.1.50 authentication id '100.1.1.60'
set vpn ipsec site-to-site peer 100.1.1.50 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 100.1.1.50 authentication pre-shared-secret 'admin@123'
set vpn ipsec site-to-site peer 100.1.1.50 authentication remote-id '100.1.1.50'
set vpn ipsec site-to-site peer 100.1.1.50 ike-group 'r5-r4-l1-ike'
set vpn ipsec site-to-site peer 100.1.1.50 local-address '100.1.1.60'
set vpn ipsec site-to-site peer 100.1.1.50 vti bind 'vti5'
set vpn ipsec site-to-site peer 100.1.1.50 vti esp-group 'r5-r4-l1-esp'
set vpn ipsec site-to-site peer 200.1.1.50 authentication id '200.1.1.60'
set vpn ipsec site-to-site peer 200.1.1.50 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 200.1.1.50 authentication pre-shared-secret 'admin@123'
set vpn ipsec site-to-site peer 200.1.1.50 authentication remote-id '200.1.1.50'
set vpn ipsec site-to-site peer 200.1.1.50 ike-group 'r5-r4-l2-ike'
set vpn ipsec site-to-site peer 200.1.1.50 local-address '200.1.1.60'
set vpn ipsec site-to-site peer 200.1.1.50 vti bind 'vti10'
set vpn ipsec site-to-site peer 200.1.1.50 vti esp-group 'r5-r4-l2-esp'
