I’ve been trying to set up 2 different BGP sessions to the routers of our hosting provider to announce a /24 ( 2 sessions for redundancy )
But it seems like only the router that my vyos is using the default route from gets it advertised as when I check on their side ( I work for the same company ) I can see that on the first router it’s being advertised as best route and shows the IP of my router.
But when I check on the second one it shows the route as being ebgp and sends it throughout the network until it comes back on router 1 whereas it should show the same as on the first one, my router IP.
The strange part is that when I shutdown the session with router 1, router 2 almost immediately shows it having the best path.
Let me show some examples: ( IP’s have been changed of course )
protocols {
bgp 1111 {
maximum-paths {
ebgp 2
neighbor 2.2.2.2. {
nexthop-self
remote-as 2222
route-map {
export rtr1-ipv4-out
import rtr1-in
soft-reconfiguration {
inbound
update-source 2.2.2.1
neighbor 2.2.2.3 {
nexthop-self
remote-as 2222
route-map {
export rtr2-ipv4-out
import rtr2-in
inbound
parameters {
graceful-restart {
log-neighbor-changes
router-id 2.2.2.1
redistribute {
static {
network 6.6.6.6/24 {
static {
route 6.6.6.6/24 {
blackhole {
distance 254
I’ve created for both routers a route-map and a prefix list.
prefix-list announce {
description "Announced networks"
rule 5 {
action permit
le 32
prefix 6.6.6.6/24
route-map rtr1-ipv4-out {
rule 10 {
action permit
match {
ip {
address {
set {
metric +5
route-map rtr1-in {
rule 5 {
action permit
set {
metric +5
The ones for rtr2 are the same only they have rtr2 in the name.
Now on the other side I see this: ( keep in mind I changed the AS and IP again, on the routers I did not use this of course )
On router 1:
sh ip bgp neighbors 2.2.2.1 received-routes
There are 1 received routes from neighbor 2.2.2.1
Searching for matching routes, use ^C to quit...
Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED
E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH
S:SUPPRESSED F:FILTERED s:STALE
Prefix Next Hop MED LocPrf Weight Status
1 6.6.6.6/24 2.2.2.1 6 100 0 BE
While on router 2 I see this:
1 6.6.6.6/24 2.2.2.1 6 100 0 E
How can I get it so that both of them show BE?
Last thing I noted was this:
# show ip route
B>* 0.0.0.0/0 [20/10] via 2.2.2.2, eth0, 00:25:51
* via 2.2.2.3, eth0, 00:25:51
As I get from both the bgp sessions a default route.
Where the 2.2.2.2 is the current active default gateway and the one currently having the BE route.
I know it’s a long story and I hope I somewhat showed what I’m having as a problem.
And OSPF is not an option here, before I get that as an answer
