Hello Guys,
I have a BGP session between the Vyos (CPE) and a other Vendor device (PE).
The PE is doing a redistribution of connected routes but I am not receiving those routes in BGP on the Vyos (CPE). I did the same peering with a Cisco router and the Cisco receives the routes from the PE but the Vyos refuses the routes (this makes me feel there is nothing wrong with the PE config). Need help to figure out if I am doing something wrong here.
vyos@vyos1:~$ show config comm | match bgp
set protocols bgp address-family ipv4-unicast network 10.250.133.36/30
set protocols bgp neighbor 10.250.133.38 address-family ipv4-unicast
set protocols bgp neighbor 10.250.133.38 remote-as ‘1234’
set protocols bgp system-as ‘65000’
vyos@vyos1:~$
vyos@vyos1:~$
vyos@vyos1:~$
vyos@vyos1:~$ show bgp summary
IPv4 Unicast Summary (VRF default):
BGP router identifier 192.168.80.3, local AS number 65000 vrf-id 0
BGP table version 364
RIB entries 1, using 192 bytes of memory
Peers 1, using 723 KiB of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd PfxSnt Desc
10.250.133.38 4 1234 160 394 0 0 0 00:01:50 0 1
Total number of neighbors 1
Jun 15 12:53:11 vyos1 bgpd[986]: [ZWCSR-M7FG9] 10.250.133.38 [FSM] TCP_connection_open (Connect->OpenSent), fd 28
Jun 15 12:53:11 vyos1 bgpd[986]: [RWZTG-AA74G] 10.250.133.38 open active, local address 10.250.133.37
Jun 15 12:53:11 vyos1 bgpd[986]: [XKJ09-9VTZ7] 10.250.133.38 Sending hostname cap with hn = vyos1, dn = (null)
Jun 15 12:53:11 vyos1 bgpd[986]: [JFFAN-DEGED] 10.250.133.38 sending OPEN, version 4, my as 65000, holdtime 180, id 192.168.80.3
Jun 15 12:53:11 vyos1 bgpd[986]: [T91AW-FGMHW] bgp_fsm_change_status : vrf default(0), Status: OpenSent established_peers 0
Jun 15 12:53:11 vyos1 bgpd[986]: [ZQHFG-DQGX1] 10.250.133.38 went from Connect to OpenSent
Jun 15 12:53:11 vyos1 bgpd[986]: [WNM1E-D314G] 10.250.133.38 rcv OPEN, version 4, remote-as (in open) 1234, holdtime 180, id 172.16.133.1
Jun 15 12:53:11 vyos1 bgpd[986]: [QG29C-5TSVS] 10.250.133.38 rcv OPEN w/ OPTION parameter len: 76
Jun 15 12:53:11 vyos1 bgpd[986]: [NVZPF-5ST3B] 10.250.133.38 rcvd OPEN w/ optional parameter type 2 (Capability) len 6
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has MultiProtocol Extensions capability (1), length 4
Jun 15 12:53:11 vyos1 bgpd[986]: [VXVH9-3MXR0] 10.250.133.38 OPEN has MultiProtocol Extensions capability for afi/safi: IPv4/unicast
Jun 15 12:53:11 vyos1 bgpd[986]: [NVZPF-5ST3B] 10.250.133.38 rcvd OPEN w/ optional parameter type 2 (Capability) len 2
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has Route Refresh (Old) capability (128), length 0
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has Route Refresh capability (2), length 0
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has Enhanced Route Refresh capability (70), length 0
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has 4-octet AS number capability (65), length 4
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has BGP Extended Message capability (6), length 0
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has AddPath capability (69), length 4
Jun 15 12:53:11 vyos1 bgpd[986]: [SBSKM-G6QBW] 10.250.133.38 OPEN has AddPath capability for afi/safi: IPv4/unicast, receive
Jun 15 12:53:11 vyos1 bgpd[986]: [NVZPF-5ST3B] 10.250.133.38 rcvd OPEN w/ optional parameter type 2 (Capability) len 28
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has FQDN capability (73), length 26
Jun 15 12:53:11 vyos1 bgpd[986]: [MR6EG-NS6N7] 10.250.133.38 received hostname PE, domainname (null)
Jun 15 12:53:11 vyos1 bgpd[986]: [NVZPF-5ST3B] 10.250.133.38 rcvd OPEN w/ optional parameter type 2 (Capability) len 4
Jun 15 12:53:11 vyos1 bgpd[986]: [SCW43-WN4M1] 10.250.133.38 OPEN has Graceful Restart capability (64), length 2
Jun 15 12:53:11 vyos1 bgpd[986]: [KDY57-R1CN0] 10.250.133.38 Peer has not restarted. Restart Time: 120, N-bit set: no
Jun 15 12:53:11 vyos1 bgpd[986]: [ZWCSR-M7FG9] 10.250.133.38 [FSM] Receive_OPEN_message (OpenSent->OpenConfirm), fd 28
Jun 15 12:53:11 vyos1 bgpd[986]: [T91AW-FGMHW] bgp_fsm_change_status : vrf default(0), Status: OpenConfirm established_peers 0
Jun 15 12:53:11 vyos1 bgpd[986]: [ZQHFG-DQGX1] 10.250.133.38 went from OpenSent to OpenConfirm
Jun 15 12:53:11 vyos1 bgpd[986]: [ZWCSR-M7FG9] 10.250.133.38 [FSM] Receive_KEEPALIVE_message (OpenConfirm->Established), fd 28
Jun 15 12:53:11 vyos1 bgpd[986]: [T91AW-FGMHW] bgp_fsm_change_status : vrf default(0), Status: Established established_peers 1
Jun 15 12:53:11 vyos1 bgpd[986]: [ZQHFG-DQGX1] 10.250.133.38 went from OpenConfirm to Established
Jun 15 12:53:11 vyos1 bgpd[986]: [MB4DQ-1WJRM] 10.250.133.38(Unknown) Update Group Hash: sort: 2 UpdGrpFlags: 0 UpdGrpAFFlags: 67108867
Jun 15 12:53:11 vyos1 bgpd[986]: [Z6NRP-471E3] 10.250.133.38(Unknown) Update Group Hash: addpath: 3 UpdGrpCapFlag: 256 UpdGrpCapAFFlag: 2048 route_adv: 0 change local as: 0
Jun 15 12:53:11 vyos1 bgpd[986]: [Z8Q37-65KK3] 10.250.133.38(Unknown) Update Group Hash: max packet size: 65535 pmax_out: 0 Peer Group: (NONE) rmap out: (NONE)
Jun 15 12:53:11 vyos1 bgpd[986]: [NTX3N-C3WZX] 10.250.133.38(Unknown) Update Group Hash: dlist out: (NONE) plist out: (NONE) aslist out: (NONE) usmap out: (NONE) advmap: (NONE)
Jun 15 12:53:11 vyos1 bgpd[986]: [V8B3M-T6VFC] 10.250.133.38(Unknown) Update Group Hash: default rmap: (NONE) shared network and afi active network: 0
Jun 15 12:53:11 vyos1 bgpd[986]: [YHMDQ-HM606] 10.250.133.38(Unknown) Update Group Hash: Lonesoul: 0 ORF prefix: 0 ORF old: 0 max prefix out: 0
Jun 15 12:53:11 vyos1 bgpd[986]: [SQ314-QBJCR] 10.250.133.38(Unknown) Update Group Hash key: 1443021452
Jun 15 12:53:11 vyos1 bgpd[986]: [P3D3N-3277A] 10.250.133.38 [FSM] Timer (routeadv timer expire)
Jun 15 12:53:12 vyos1 bgpd[986]: [K9G3A-CJ5QQ] u119:s127 announcing routes upon coalesce timer expiry(1050 ms)
Jun 15 12:53:12 vyos1 bgpd[986]: [P3D3N-3277A] 10.250.133.38 [FSM] Timer (routeadv timer expire)
Jun 15 12:53:12 vyos1 bgpd[986]: [TN0HX-6G1RR] u119:s127 send UPDATE w/ attr: nexthop 0.0.0.0, origin i, mp_nexthop ::, metric 0, path
Jun 15 12:53:12 vyos1 bgpd[986]: [HVRWP-5R9NQ] u119:s127 send UPDATE 10.250.133.36/30 IPv4 unicast
Jun 15 12:53:12 vyos1 bgpd[986]: [WEV7K-2GAQ5] u119:s127 send UPDATE len 56 (max message len: 65535) numpfx 1
Jun 15 12:53:12 vyos1 bgpd[986]: [MBFVT-8GSC6] u119:s127 10.250.133.38 send UPDATE w/ nexthop 10.250.133.37
Jun 15 12:53:12 vyos1 bgpd[986]: [ZP3RE-J4Q8C] send End-of-RIB for IPv4 Unicast to 10.250.133.38
