Hi there,
Has anyone make BGP or OSPF work with AWS via Vyos.
I tried to use GRE tunnels to talk either BGP or OSPF, it doesn’t work for some reason
Hi there,
Do you mean that you need to talk BGP with the AWS gateway of your network? I am doing that with IPSec tunnels and BGP. AWS does not talk OSPF.
I found my problem to making OSPF and BGP work in AWS.
There is a few step to get it prepare like static routes and gre tunnels for it to work properly and also additional backup routers need to restart , otherwise the state stuck in ExStart
