Please let me know if there is an error in my configuration, I redistribute connected on BGP with additional route-map but the prefix/ip connected via PPPoE interface is not advertised to peer bgp.
set policy route-map EXPORT-INTERNAL rule 10 action 'permit'
set policy route-map EXPORT-INTERNAL rule 10 match ip address prefix-list 'EXPORT-COMMUNITY-1111'
set policy route-map EXPORT-INTERNAL rule 10 set community '55666:1111'
set policy route-map EXPORT-INTERNAL rule 10 set local-preference '110'
set policy route-map EXPORT-INTERNAL rule 9999 action 'deny'
set protocols bgp XXXXXX address-family ipv4-unicast redistribute connected route-map 'EXPORT-INTERNAL'
set protocols bgp XXXXXX address-family ipv4-unicast redistribute static route-map 'EXPORT-INTERNAL'
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 address-family ipv4-unicast nexthop-self
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 address-family ipv4-unicast route-map export 'EXPORT-INTERNAL'
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 address-family ipv4-unicast route-map import 'IMPORT-BR1'
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 address-family ipv4-unicast route-reflector-client
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 address-family ipv4-unicast soft-reconfiguration inbound
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 description 'BR1'
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 remote-as '55666'
set protocols bgp XXXXXX neighbor xxx.xxx.54.129 update-source 'xxx.xxx.54.162'
[email protected]:~$ show pppoe-server sessions
ifname | username | ip | ip6 | ip6-dp | calling-sid | rate-limit | state | uptime | rx-bytes | tx-bytes
ppp0 | 01.0281-01.gmedia.net.id | 111.68.25.242 | | | ec:f0:fe:87:df:f0 | | active | 00:00:06 | 116 B | 206 B
[email protected]:~$ show ip bgp neighbors 119.2.54.129 advertised-routes
BGP table version is 235571, local router ID is 10.251.251.110, vrf id 0
Default local pref 100, local AS 55666
Nexthop codes: @NNN nexthop's vrf id, < announce-nh-self
*> 111.68.26.239/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.112/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.113/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.114/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.115/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.116/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.117/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.118/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.119/32 0.0.0.0 0 110 32768 ?
*> 111.68.29.204/30 0.0.0.0 0 110 32768 ?
*> 116.254.119.128/32
*> 116.254.119.129/32
*> 116.254.119.130/32
*> 116.254.119.131/32
*> 116.254.119.132/32
*> 116.254.119.133/32
*> 116.254.119.134/32
*> 116.254.119.135/32
*> 119.2.52.252/32 0.0.0.0 0 110 32768 i
Total number of prefixes 19
Thanks.
