Billy, Carl, thanks for your response. For some reason, I did not get email notifications. Must have forgot to subscribe.
Billy, I cannot do OSPF, GRE etc. All of these are in Amazon VPC. One end of the tunnels are Amazon VPC VPN’s which I don’t have control over.
Carl, I am attaching my configurations along with a picture to make this clear.
From the attached configuration, you can see that each VyOS has 4 tunnels. 2 tunnels are used for each remote region. VyOS in the hub region advertises a broader 10.0.0.0/8 subnet to all the spoke regions.
What I am trying to figure out is, if the BGP routes learned from one tunnel can be redistributed to other tunnels?
All your neighbors are in AS7224. If you learn a route on one tunnel, its bgp path (as seen on your vyos) will start with 65000 7224. If one of the other neighbors accepted that route, the path would then start with 7224 65000 7224.
I don’t think BGP will even try to redistribute such a route - as7224 is presumed to already know it.
Can you do ebgp-multihop to a bgp router on the other end of the tunnel? If the tunnel is up you talk bgp and exchange routing prefixes. When the tunnel goes down, the announcements go away and the routes disappear.
update-source should be set to the ip on your end of the tunnel, which is the same address that the far end should use for neighbor. The far end sets update-source to their end of the tunnel, which matches your neighbor address. I am confused about these tunnels. Are both ends of those tunnels terminating on your vyos devices?
Yes, in that case, your vyos should advertise into 7225 routes that it learns from 7224. Debug that with:
show ip bgp neighbor IP4ADDR advertised-routes
show ip bgp neighbor IP4ADDR received-routes
However, the internal addresses used inside each vpc (and routes to those networks given to you via bgp from amazon over the tunnels) are probably duplicated inside other folks amazon vpcs. Amazon almost surely won’t accept a route into 7224 that originated in 7225.
Are you trying to get machines inside vpc1 to talk to machines inside vpc2? Even if amazon did accept such routes from you, all the traffic between your machines in those two vpcs would flow thru your vyos - essentially you would be providing transit between those two vpcs. Is that actually what you are trying to achieve? Amazon might have some mechanism to provide connectivity between those two regions that would be more efficient than piping it all thru your vyos.
Sorry, did not see your post. Yes, I am trying to connect multiple Amazon regions using VyOS using a hub-spoke model.
Region1 -> HubRegion (VyOS) <- Region2 …
The problem I am trying to solve is out-bound traffic high availability. Amazon unfortunately does not provide a very efficient solution for cross connecting regions.
Hi vyos@pasam. I am runnning into same situation you faced. i know this is old threadh, but will appreciate if you can let me know how you solved this. basically, i’m connecting OR-vpc-1 and SG VPC and also using the “cloud-hub” like config, so that my on premises devices can talk to each other via AWS VPG. one vyos in OR-vpc-2 is connected to to both SG and OR-vpc-1 vpg. even the OR-vpc-1 vpg can learn the bgp routes from SG side, but SG side only learning one route (OR vpc-vpc-2 network, static route).
Any help will deeply appreciated.
you can mail me on [email protected]
Thanks,
Ashish
