Issuing “show ip route” shows connected, static and ospf routes but no BGP routes:
S>* ::/0 [1/0] via fe80::2, bond0
C>* ::1/128 is directly connected, lo
S>* 2001:67c:88::/48 [250/0], bh
O 2001:67c:88:f0::224/128 [110/1] via ::1, 1d09h16m
C>* 2001:67c:88:f0::224/128 is directly connected, lo
O>* 2001:67c:88:f0::225/128 [110/2] via fe80::290:bff:fe1e:4cae, bond2, 1d09h16m
O 2001:67c:88:f0::226/127 [110/1] is directly connected, bond2, 1d09h16m
C>* 2001:67c:88:f0::226/127 is directly connected, bond2
O 2001:67c:88:f0::228/127 [110/1] is directly connected, bond1, 2d04h32m
C>* 2001:67c:88:f0::228/127 is directly connected, bond1
O>* 2001:67c:88:f0::230/127 [110/2] via fe80::290:bff:fe1e:4cae, bond2, 1d09h16m
S>* 2001:67c:2c28::/48 [250/0], bh
C>* 2a02:418:39aa:11::/64 is directly connected, bond0
O>* 2a02:418:69aa:11::/64 [110/1] via fe80::290:bff:fe1e:4cae, bond2, 1d09h16m
O>* 2a02:418:6a06::/48 [110/2] via fe80::768e:f8ff:fe2d:5100, bond1, 2d04h32m
C * fe80::/64 is directly connected, bond2
C * fe80::/64 is directly connected, bond0
C * fe80::/64 is directly connected, bond1
C>* fe80::/64 is directly connected, eth2
Looking at a BGP session there should be a default route installed:
vyos@cr1# run sh ipv6 bgp neighbors X received-routes
BGP table version is 0, local router ID is 91.199.218.224
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, R Removed
*> ::/0 2a02:418:39aa:11::1
0 0 29691 i
Total number of prefixes 1
Any ideas why this route is not installed into the routing table?
Cheers,
Tobias
