Hi all,
I’m working my way through the Manito Networks CompTIA Network+ Routing Labs in preparation for my exam, which uses VyOS as the virtual router. This is great, of course, as an option for learning routing using VyOS instead of Cisco. Highly recommended!
The material uses VyOS 1.1.8, which is quite dated at this point, so I’m trying to do it with a current rolling release. I’m through nearly everything (static, RIPv2, single area OSPF, multi-area OSPF) and it’s been great, but just got snagged on iBGP when trying to configure a neighbor route reflection.
The code I’m trying to add is in a snippet here (the forum topic editor keeps messing up the format), and starts complaining specifically when I get to
set neighbor 10.255.255.2 route-reflector-client
with the error message of
Configuration path: neighbor 10.255.255.2 [route-reflector-client] is not valid
Set failed
I checked the Vyatta reference documentation and this appears to be correct, so perhaps something changed since the 1.1.8 release?
I’m still learning BGP, particularly in VyOS, so am stuck trying to finish the lab ![]()
Any help is appreciated!
