I noticed that bgp peers in our vyatta were not coming up with their their PE connections. All settings seemed to be correct, and the interface shows U/U. The only way I could get the bgp connection to come up was to disable the sub interfaces on the vyatta, then enable it again.
Is this expected?
we’re going to need more information , what version are you using ?
is it possible to reach ipv4 configured sub-interface ?
could you share your current configuration ?
1.4-rolling-202212130326 (default boot)
I cannot ping the far end interface (10.30.20.0/31). Yes I am pinging from the correct vrf.
Below I share the config, I will share other troubleshooting I tried:
- Tried adding the configuration of the CE (vyatta) leaf first then the PE after. No change
- Tried adding the configuration of the PE leaf first then the CE (vyatta) after. No change
- Only thing that works is make sure the PE configuration is in place, then configure the vyatta, and bounce the interface.
set interfaces ethernet eth1 vif 3520 address '10.35.20.1/24'
set interfaces ethernet eth1 vif 3520 vrf 'cust20'
set interfaces ethernet eth2 hw-id '00:50:56:96:eb:8a'
set interfaces ethernet eth2 vif 3020 address '10.30.20.1/31'
set interfaces ethernet eth2 vif 3020 vrf 'cust20'
set interfaces loopback lo
set policy prefix-list cust20-network rule 1 action 'permit'
set policy prefix-list cust20-network rule 1 prefix '10.35.20.0/24'
set policy route-map cust20-import-bgp-routes rule 1 action 'permit'
set policy route-map cust20-import-bgp-routes rule 1 match ip route-source prefix-list '10.30.20.0/31'
set service ssh
set system host-name 'router'
set system login user vyos authentication encrypted-password REMOVED
set system ntp server time1.vyos.net
set system ntp server time2.vyos.net
set system ntp server time3.vyos.net
set vrf name cust20 protocols bgp address-family ipv4-unicast network 10.35.20.0/24
set vrf name cust20 protocols bgp neighbor 10.30.20.0 address-family ipv4-unicast prefix-list export 'cust20-network'
set vrf name cust20 protocols bgp neighbor 10.30.20.0 remote-as '65250'
set vrf name cust20 protocols bgp route-map 'cust20-import-bgp-routes'
set vrf name cust20 protocols bgp system-as '65020'
set vrf name cust20 table '3020'
I not sure what is the propose this configuration ,considered in verify the network address . however , Could you try the following ? :
1- add the update-source in BGP:
set vrf name cust20 protocols bgp neighbor 10.30.20.0 update-source '10.30.20.1'
2- add router-id
set vrf name cust20 protocols bgp parameters router-id '10.30.20.1'
you should check if it’s possible to reachet from 10.30.20.1 to 10.30.20.0 , using as vrf configured :
3- ping from VRF
ping 10.30.20.0 source-address 10.30.20.1 vrf cust20
4- add this command set vrf bind-to-all
