BGP Weight Route / Prefered Route
How i can modify weight route from :
show ip route
To configure prefered route, or this is not the good way to configure prefered route.
If a check documentation i can see different way to modify route :
https://docs.vyos.io/en/equuleus/configuration/protocols/bgp.html
  1. Weight checkPrefer higher local weight routes to lower routes.
  2. Local preference checkPrefer higher local preference routes to lower.
  3. Local route checkPrefer local routes (statics, aggregates, redistributed) to received routes.
  4. AS path length checkPrefer shortest hop-count AS_PATHs.
Thanks.
I recommend to use “local-preference”
You need create a prefix-list (not necessary) , route-map
set desired “local-pref” for match prefix-list
Permit/deny others prefixes
Attach route-map to neighbor for “import”
My configuration.
GNS 3 LAB :
CONFIGURATION EXTRACT :
set policy prefix-list AS67690-OUT rule 1 action ‘permit’
set policy prefix-list AS67690-OUT rule 1 ge ‘24’
set policy prefix-list AS67690-OUT rule 1 prefix ‘0.0.0.0/0’
set policy route-map AS67690-OUT rule 1 action ‘permit’
set policy route-map AS67690-OUT rule 1 match ip address prefix-list ‘AS67690-OUT’
set policy route-map AS67690-OUT rule 1 set local-preference ‘60000’
set policy route-map AS67690-OUT rule 1 set metric ‘60000’
set policy route-map AS67690-OUT rule 1 set weight ‘60000’
set protocols bgp 67690 neighbor 102.102.102.5 address-family ipv4-unicast route-map import ‘AS67690-OUT’
set protocols bgp 67690 neighbor 105.105.105.8 address-family ipv4-unicast route-map import ‘AS67690-OUT’
Router Connected to this one :
