Hello guys,
In the last days we have some UDP DDOS on some ips, we have fastnetmon with blackhole to blackhole ips but the problem is now, this guy who make DDOS it makes now right on the gateway subnet
We set on router firewall all-ping disable but still can UDP the gateways of ower ip ranges.
on the eth5 we have set the gateways.
Is there a way to protect this gateways for not respondig somehow but not to affect ower servers ?
If we blackhole .1 i think the entire ip range will not work, i dint try
Thank you
