Bridge interface isolated issue after reboot ( bridge member isolated)
Hi!
Version: VyOS 1.5-rolling-202409300007
After host rebooted isolation does not up.
Woking
Vyos int bridge memebers:
set interfaces bridge br1 member interface eth1.21 isolated
set interfaces bridge br1 member interface eth1.32 isolated
bridge -d link
21: eth1.21@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br1 state forwarding priority 32 cost 5
hairpin off guard off root_block off fastleave off learning on flood on mcast_flood on bcast_flood on mcast_router 1 mcast_to_unicast off neigh_suppress off neigh_vlan_suppress off vlan_tunnel off isolated on locked off mab off mcast_n_groups 0 mcast_max_groups 0
24: eth1.32@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br1 state forwarding priority 32 cost 5
Make reboot and …
After host rebooted isolations does not up.
Main config still here:
But if i do bridge -d link i have next output and loops
hairpin off guard off root_block off fastleave off learning on flood on mcast_flood on bcast_flood on mcast_router 1 mcast_to_unicast off neigh_suppress off neigh_vlan_suppress off vlan_tunnel off isolated off locked off mab off mcast_n_groups 0 mcast_max_groups 0
After manual
sudo bridge link set dev eth1.21 isolated on
sudo bridge link set dev eth1.32 isolated on all work properly
Is it any capability to have working β€œisolated on” bridge member interfaces always after host rebooted?
Hi!
UPD.
I`ve found a solution in VyOS Documentation.
So, what exactly did you add to postconfig?
@syncer
I just added in each interface via nano like this:
That`s all. After reboot I see β€œisolated on” if bridge -d link executed. It works in my case :+1:
Thanks for sharing the solution! i will see if we can fix that so it will not require anything
please, check with a update version , I’ve tested this configuration and works as expected :
vyos@vyos:~$ show configuration commands | match br
set interfaces bridge br0 description 'test-iso'
set interfaces bridge br0 member interface eth1.10 isolated
set interfaces bridge br0 member interface eth1.20 isolated
value on our bridge :
vyos@vyos:~$ sudo bridge -d link
7: eth1.10@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br0 state forwarding priority 32 cost 100
    hairpin off guard off root_block off fastleave off learning on flood on mcast_flood on bcast_flood on mcast_router 1 mcast_to_unicast off neigh_suppress off neigh_vlan_suppress off vlan_tunnel off **isolated on** locked off mab off mcast_n_groups 0 mcast_max_groups 0
8: eth1.20@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 master br0 state forwarding priority 32 cost 100
logic is present in our code :
vyos version :
vyos@vyos:~$ show version
Version:          VyOS 1.5-rolling-202410110006
Release train:    current
Release flavor:   generic
Built on:         Fri 11 Oct 2024 00:07 UTC
Build UUID:       733bf917-299f-4c47-a7cd-c092c1a84f0a
Build commit ID:  cde77d07d1615f
Architecture:     x86_64
System type:      KVM guest
Secure Boot:      n/a (BIOS)
Hardware vendor:  QEMU
Hardware model:   Standard PC (i440FX + PIIX, 1996)
Hardware S/N:
Hardware UUID:    5716411f-7870-44eb-8683-3ea09cdeba67
I created a bug report βš“ T6775 Bridge: the isolation option disappears after reboot
Hi!
@Viacheslav
Any updates about bug?
