Currently, I have two physical hosts. When my VYOS (version 1.2.1) is migrated to a network card type Broadcom COrporation, I find that SSH cannot work. When migrating back to another network card type intel® Ethernet Controller, SSH works normally.
When another VYOS version is 1.1.7, SSH works normally on both physical hosts
I configure QinQ mode for any version of VYOS interface。
Is Broadcom Corporation not supporting VYOS 1.2.1 version QinQ mode?
henryj@tpa-vnvy201# run show interfaces | strip-private
eth0 - u/u SCL Side
eth0.795 - u/u
eth0.795.201 xxx.xxx.95.129/31 u/u
eth1 - u/u VPN Side
eth1.796 - u/u
eth1.796.201 xxx.xxx.248.2/30 u/u
lo xxx.xxx.0.1/8 u/u
::1/128
@Henry maybe these ports have different sequences? I mean eth0 this is eth1…
If you use QinQ on eth1 too, check please also ethertype
And also you need to increase MTU on both interfaces
