Bug Kernel pcieport
Dear colleague
I have the following log, can you help me check it?
Jun 24 13:38:34 kernel: xhci_hcd 0000:08:00.0: [ 0] RxErr
Jun 24 13:38:35 kernel: pcieport 0000:00:1d.3: AER: Corrected error message received from 0000:08:00.0
Jun 24 13:38:35 kernel: xhci_hcd 0000:08:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Jun 24 13:38:35 kernel: xhci_hcd 0000:08:00.0: device [1b21:2142] error status/mask=00000001/00002000
Are you seeing any other problems except for the error in dmesg? Is there a USB device that’s dropping out? Are continuous log entries making the console unusable?
The log entries you’ve posted seem to relate to bus power management and the USB3 host controller, but in a lot of cases where it’s just a one-off after a wake-up or long idle, can be safely ignored.
Hi alifiandzaki!
could you please provide the output of a sudo lspci -vv and sudo lspci -tvv ?
The log always appears every minute continuously
root@Ro:/home/alifiandzaki# sudo lspci -vv
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
        DeviceName: Onboard - Other
        Subsystem: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
        Latency: 0
        Capabilities: [e0] Vendor Specific Information: Len=10 <?>
        Kernel driver in use: skl_uncore
        Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07) (prog-if 00 [Normal decode])
        Subsystem: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 122
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: [disabled] [16-bit]
        Memory behind bridge: df000000-df1fffff [size=2M] [32-bit]
        Prefetchable memory behind bridge: bb000000-bdbfffff [size=44M] [32-bit]
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [88] Subsystem: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16)
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
                Address: fee00238  Data: 0000
        Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0
                        ExtTag- RBE+
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 256 bytes, MaxReadReq 128 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #2, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <256ns, L1 <8us
                        ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 8GT/s, Width x8
                        TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt+
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #1, PowerLimit 75W; Interlock- NoCompl+
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState-
                RootCap: CRSVisible-
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis- NROPrPrP- LTR+
                         10BitTagComp- 10BitTagReq- OBFF Via WAKE#, ExtFmt- EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd-
                         AtomicOpsCap: Routing- 32bit+ 64bit+ 128bitCAS+
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Via WAKE#, ARIFwd-
                         AtomicOpsCtl: ReqEn- EgressBlck-
                LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
                         EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [100 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Capabilities: [140 v1] Root Complex Link
                Desc:   PortNumber=02 ComponentID=01 EltType=Config
                Link0:  Desc:   TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
                        Addr:   00000000fed19000
        Capabilities: [d94 v1] Secondary PCI Express
                LnkCtl3: LnkEquIntrruptEn- PerformEqu-
                LaneErrStat: 0
        Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] (prog-if 00 [VGA controller])
        DeviceName: Onboard - Video
        Subsystem: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 11
        Region 0: Memory at de000000 (64-bit, non-prefetchable) [size=16M]
        Region 2: Memory at c0000000 (64-bit, prefetchable) [size=256M]
        Region 4: I/O ports at f000 [size=64]
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: [40] Vendor Specific Information: Len=0c <?>
        Capabilities: [70] Express (v2) Root Complex Integrated Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag- RBE+ FLReset+
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                DevCap2: Completion Timeout: Not Supported, TimeoutDis- NROPrPrP- LTR-
                         10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
                         FRS-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
        Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
                Address: 00000000  Data: 0000
        Capabilities: [d0] Power Management version 2
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [100 v1] Process Address Space ID (PASID)
                PASIDCap: Exec- Priv-, Max PASID Width: 14
                PASIDCtl: Enable- Exec- Priv-
        Capabilities: [200 v1] Address Translation Service (ATS)
                ATSCap: Invalidate Queue Depth: 00
                ATSCtl: Enable-, Smallest Translation Unit: 00
        Capabilities: [300 v1] Page Request Interface (PRI)
                PRICtl: Enable- Reset-
                PRISta: RF- UPRGI- Stopped+
                Page Request Capacity: 00008000, Page Request Allocation: 00000000
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
        Subsystem: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
        Region 0: Memory at df92f000 (64-bit, non-prefetchable) [size=4K]
        Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
        Capabilities: [dc] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [f0] PCI Advanced Features
                AFCap: TP+ FLR+
                AFCtrl: FLR-
                AFStatus: TP-
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller (prog-if 30 [XHCI])
        Subsystem: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 130
        Region 0: Memory at df910000 (64-bit, non-prefetchable) [size=64K]
        Capabilities: [70] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
                Address: 00000000fee00378  Data: 0000
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation 200 Series PCH Thermal Subsystem
        Subsystem: Intel Corporation 200 Series PCH Thermal Subsystem
        Latency: 0
        Interrupt: pin C routed to IRQ 11
        Region 0: Memory at df92e000 (64-bit, non-prefetchable) [size=4K]
        Capabilities: [50] Power Management version 3
        Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
        Subsystem: Intel Corporation 200 Series PCH CSME HECI
        Latency: 0
        Interrupt: pin A routed to IRQ 258
        Region 0: Memory at df92d000 (64-bit, non-prefetchable) [size=4K]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
        Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fee01378  Data: 0000
        Kernel driver in use: mei_me
        Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode] (prog-if 01 [AHCI 1.0])
        DeviceName: Onboard - SATA
        Subsystem: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 136
        Region 0: Memory at df928000 (32-bit, non-prefetchable) [size=8K]
        Region 1: Memory at df92c000 (32-bit, non-prefetchable) [size=256]
        Region 2: I/O ports at f090 [size=8]
        Region 3: I/O ports at f080 [size=4]
        Region 4: I/O ports at f060 [size=32]
        Region 5: Memory at df92b000 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
                Address: fee00438  Data: 0000
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0) (prog-if 00 [Normal decode])
        Subsystem: Intel Corporation 200 Series PCH PCI Express Root Port
        Interrupt: pin A routed to IRQ 123
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        I/O behind bridge: e000-efff [size=4K] [16-bit]
        Memory behind bridge: df800000-df8fffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
                        ExtTag- RBE+
                DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
                LnkCap: Port #5, Speed 8GT/s, Width x1, ASPM not supported
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                LnkSta: Speed 2.5GT/s, Width x1
                        TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                        Slot #8, PowerLimit 10W; Interlock- NoCompl+
                        Changed: MRL- PresDet- LinkState+
                DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR+
                         FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd+
                         AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Disabled, ARIFwd-
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                Address: fee00258  Data: 0000
        Capabilities: [90] Subsystem: Intel Corporation 200 Series PCH PCI Express Root Port
        Capabilities: [a0] Power Management version 3
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
                RootCmd: CERptEn+ NFERptEn+ FERptEn+
                RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
                         FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
                ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
        Capabilities: [140 v1] Access Control Services
                ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Capabilities: [220 v1] Secondary PCI Express
                LaneErrStat: 0
00:1c.5 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #6 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin B routed to IRQ 124
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: d000-dfff [size=4K] [16-bit]
        Memory behind bridge: df700000-df7fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                LnkCap: Port #6, Speed 8GT/s, Width x1, ASPM not supported
                        Slot #9, PowerLimit 10W; Interlock- NoCompl+
                Address: fee00298  Data: 0000
                LaneErrStat: 0
00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin C routed to IRQ 125
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: c000-cfff [size=4K] [16-bit]
        Memory behind bridge: df600000-df6fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                LnkCap: Port #7, Speed 8GT/s, Width x1, ASPM not supported
                        Slot #10, PowerLimit 10W; Interlock- NoCompl+
                Address: fee002d8  Data: 0000
                LaneErrStat: 0
00:1c.7 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #8 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin D routed to IRQ 126
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: b000-bfff [size=4K] [16-bit]
        Memory behind bridge: df500000-df5fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                LnkCap: Port #8, Speed 8GT/s, Width x1, ASPM not supported
                        Slot #11, PowerLimit 10W; Interlock- NoCompl+
                Address: fee002f8  Data: 0000
                LaneErrStat: 0
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 127
        Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
        I/O behind bridge: a000-afff [size=4K] [16-bit]
        Memory behind bridge: df400000-df4fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                LnkCap: Port #9, Speed 8GT/s, Width x1, ASPM not supported
                        Slot #12, PowerLimit 10W; Interlock- NoCompl+
                Address: fee00318  Data: 0000
                LaneErrStat: 0
00:1d.1 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #10 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin B routed to IRQ 128
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
        I/O behind bridge: 9000-9fff [size=4K] [16-bit]
        Memory behind bridge: df300000-df3fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                LnkCap: Port #10, Speed 8GT/s, Width x1, ASPM not supported
                        Slot #13, PowerLimit 10W; Interlock- NoCompl+
                Address: fee00338  Data: 0000
                LaneErrStat: 0
00:1d.3 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #12 (rev f0) (prog-if 00 [Normal decode])
        Interrupt: pin D routed to IRQ 129
        Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
        Memory behind bridge: df200000-df2fffff [size=1M] [32-bit]
                        ExtTag- RBE+
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
                LnkCap: Port #12, Speed 8GT/s, Width x1, ASPM not supported
                LnkSta: Speed 8GT/s, Width x1
                        Slot #15, PowerLimit 10W; Interlock- NoCompl+
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
                Address: fee00358  Data: 0000
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                ErrorSrc: ERR_COR: 0800 ERR_FATAL/NONFATAL: 0000
                LaneErrStat: 0
00:1f.0 ISA bridge: Intel Corporation 200 Series PCH LPC Controller (Q250)
        Subsystem: Intel Corporation 200 Series PCH LPC Controller (Q250)
        Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
        Subsystem: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
        Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Region 0: Memory at df924000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
        DeviceName: Onboard - Sound
        Subsystem: Intel Corporation 200 Series PCH HD Audio
        Latency: 32, Cache Line Size: 64 bytes
        Region 0: Memory at df920000 (64-bit, non-prefetchable) [size=16K]
        Region 4: Memory at df900000 (64-bit, non-prefetchable) [size=64K]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
        Subsystem: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin A routed to IRQ 16
        Region 0: Memory at df92a000 (64-bit, non-prefetchable) [size=256]
        Region 4: I/O ports at f040 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
        Subsystem: Intel Corporation Ethernet Converged Network Adapter X710
        Region 0: Memory at bb000000 (64-bit, prefetchable) [size=8M]
        Region 3: Memory at bd800000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at df180000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00001000
        Capabilities: [a0] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM L1, Exit Latency L1 <16us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
                         FRS- TPHComp- ExtTPHComp-
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
        Capabilities: [100 v2] Advanced Error Reporting
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
        Capabilities: [140 v1] Device Serial Number 4b-21-23-ff-ff-a8-90-00
        Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
                ARICap: MFVC- ACS-, Next Function: 1
                ARICtl: MFVC- ACS-, Function Group: 0
        Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
                IOVCap: Migration- 10BitTagReq- Interrupt Message Number: 000
                IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy- 10BitTagReq-
                IOVSta: Migration-
                Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 00
                VF offset: 272, stride: 1, Device ID: 154c
                Supported Page Size: 00000553, System Page Size: 00000001
                Region 0: Memory at 00000000bd000000 (64-bit, prefetchable)
                Region 3: Memory at 00000000bd820000 (64-bit, prefetchable)
                VF Migration: offset: 00000000, BIR: 0
        Capabilities: [1a0 v1] Transaction Processing Hints
                Device specific mode supported
                No steering table available
        Capabilities: [1b0 v1] Access Control Services
                ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Capabilities: [1d0 v1] Secondary PCI Express
                LaneErrStat: 0
        Kernel driver in use: i40e
        Kernel modules: i40e
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
        Region 0: Memory at bb800000 (64-bit, prefetchable) [size=8M]
        Region 3: Memory at bd808000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at df100000 [disabled] [size=512K]
                ARICap: MFVC- ACS-, Next Function: 2
                IOVSta: Migration-
                Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 01
                VF offset: 303, stride: 1, Device ID: 154c
                Region 0: Memory at 00000000bd200000 (64-bit, prefetchable)
                Region 3: Memory at 00000000bd8a0000 (64-bit, prefetchable)
01:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
        Region 0: Memory at bc000000 (64-bit, prefetchable) [size=8M]
        Region 3: Memory at bd810000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at df080000 [disabled] [size=512K]
                ARICap: MFVC- ACS-, Next Function: 3
                IOVSta: Migration-
                Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 02
                VF offset: 334, stride: 1, Device ID: 154c
                Region 0: Memory at 00000000bd400000 (64-bit, prefetchable)
                Region 3: Memory at 00000000bd920000 (64-bit, prefetchable)
01:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
        Region 0: Memory at bc800000 (64-bit, prefetchable) [size=8M]
        Region 3: Memory at bd818000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at df000000 [disabled] [size=512K]
                ARICap: MFVC- ACS-, Next Function: 0
                IOVSta: Migration-
                Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 03
                VF offset: 365, stride: 1, Device ID: 154c
                Region 0: Memory at 00000000bd600000 (64-bit, prefetchable)
                Region 3: Memory at 00000000bd9a0000 (64-bit, prefetchable)
02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Subsystem: Intel Corporation I210 Gigabit Network Connection
        Region 0: Memory at df800000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at e000 [size=32]
        Region 3: Memory at df820000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
                PBA: BAR=3 offset=00002000
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-bf
                Steering table in TPH capability structure
        Kernel driver in use: igb
        Kernel modules: igb
03:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at df700000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at d000 [size=32]
        Region 3: Memory at df720000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-c0
        Kernel modules: igb
04:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Interrupt: pin A routed to IRQ 18
        Region 0: Memory at df600000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at c000 [size=32]
        Region 3: Memory at df620000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-c1
        Kernel modules: igb
05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Interrupt: pin A routed to IRQ 19
        Region 0: Memory at df500000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at b000 [size=32]
        Region 3: Memory at df520000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-c2
        Kernel modules: igb
06:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Region 0: Memory at df400000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at a000 [size=32]
        Region 3: Memory at df420000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-c3
        Kernel modules: igb
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
        Region 0: Memory at df300000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at 9000 [size=32]
        Region 3: Memory at df320000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [140 v1] Device Serial Number 04-2b-58-ff-ff-12-6a-c4
        Kernel modules: igb
08:00.0 USB controller: ASMedia Technology Inc. ASM2142/ASM3142 USB 3.1 Host Controller (prog-if 30 [XHCI])
        Subsystem: ASMedia Technology Inc. ASM2142/ASM3142 USB 3.1 Host Controller
        Region 0: Memory at df200000 (64-bit, non-prefetchable) [size=32K]
        Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
        Capabilities: [68] MSI-X: Enable+ Count=8 Masked-
                Vector table: BAR=0 offset=00002000
                PBA: BAR=0 offset=00002080
        Capabilities: [78] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [80] Express (v2) Legacy Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <2us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                LnkCap: Port #0, Speed 8GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
                LnkSta: Speed 8GT/s, Width x1 (downgraded)
                         FRS-
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap- ECRCChkEn-
        Capabilities: [200 v1] Secondary PCI Express
                LaneErrStat: LaneErr at lane: 0
        Capabilities: [300 v1] Latency Tolerance Reporting
                Max snoop latency: 3145728ns
                Max no snoop latency: 3145728ns
        Capabilities: [400 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=0us PortTPowerOnTime=10us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=0us LTR1.2_Threshold=0ns
                L1SubCtl2: T_PwrOn=44us
root@Ro:/home/alifiandzaki# sudo lspci -tvv
-[0000:00]-+-00.0  Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers
           +-01.0-[01]--+-00.0  Intel Corporation Ethernet Controller X710 for 10GbE SFP+
           |            +-00.1  Intel Corporation Ethernet Controller X710 for 10GbE SFP+
           |            +-00.2  Intel Corporation Ethernet Controller X710 for 10GbE SFP+
           |            \-00.3  Intel Corporation Ethernet Controller X710 for 10GbE SFP+
           +-02.0  Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
           +-08.0  Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
           +-14.0  Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
           +-14.2  Intel Corporation 200 Series PCH Thermal Subsystem
           +-16.0  Intel Corporation 200 Series PCH CSME HECI #1
           +-17.0  Intel Corporation 200 Series PCH SATA controller [AHCI mode]
           +-1c.0-[02]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1c.5-[03]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1c.6-[04]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1c.7-[05]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1d.0-[06]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1d.1-[07]----00.0  Intel Corporation I210 Gigabit Network Connection
           +-1d.3-[08]----00.0  ASMedia Technology Inc. ASM2142/ASM3142 USB 3.1 Host Controller
           +-1f.0  Intel Corporation 200 Series PCH LPC Controller (Q250)
           +-1f.2  Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
           +-1f.3  Intel Corporation 200 Series PCH HD Audio
           \-1f.4  Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
Hi!
in reference to the original error, this looks to be a issue communicating between the CPU (0000:08:00.0) and a ASMedia USB 3.1 host controller (0000:00:1d.3) in this system.
Is the ASMedia usb3.1 controller a integrated part of your system or is this a pci’e addin-card on this system?
If it is a addin-card, you could try reseating the card in its slot or move it to another slot.
I can’t do that because the tool is already running and passing 3Gbps traffic
