Seems like the forum interprets anything between < and > as a html code which means if you type < prefix >::1 only ::1 will be visible when reading the post (but the whole text will be visible during edit).
Would it be possible to change this somehow or can I in my profile disable “html code” when posting messages?
I hope you had a good weekend! I’ve thoroughly reviewed the settings, and unfortunately, there doesn’t seem to be a direct method to disable it. However, I will explore the possibility of integrating a custom component to address this issue. I will keep you update once I find a suitable solution.
