Build Error ,the following packages have unmet dependencies
vyos-1x : Depends: fuse-overlayfs but it is not going to be installed
Depends: vyatta-cfg but it is not installable
vyos-world : Depends: vyatta-cfg-system but it is not going to be installed
Depends: vyatta-op but it is not going to be installed
Depends: vyatta-cluster but it is not going to be installed
Depends: vyatta-wanloadbalance but it is not going to be installed
E: An unexpected failure occurred, exiting…
P: Saving caches…
Please provide the steps you did in order for us to assist you.
Also you may refer to this documentation for the procedure. Thanks!
Last week, the same steps were successfully built, but there have been errors in the past two days.
./build-vyos-image iso --architecture arm64 --build-by “xxxxxxxx” --custom-apt-entry “deb [arch=arm64] InfluxData - Package Repository bullseye stable” --custom-apt-key /vyos/influxdata-archive_compat.key
No Vyatta-cfg arm64 deb package
