I followed the default build directions for building the iso via docker and received the errors in the log. Why and how to fix?
dpkg: dependency problems prevent configuration of vyatta-cfg-firewall:
vyatta-cfg-firewall depends on vyatta-cfg (>= 0.15.33); however:
Package vyatta-cfg is not configured yet.
vyatta-cfg-firewall depends on vyatta-cfg-system (>= 0.19.125); however:
Package vyatta-cfg-system is not configured yet.
dpkg: error processing package vyatta-cfg-firewall (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of vyatta-op:
vyatta-op depends on vyatta-cfg (>= 0.16.26); however:
vyatta-op depends on vyatta-cfg-system (>= 0.19.93); however:
dpkg: error processing package vyatta-op (--configure):
dpkg: dependency problems prevent configuration of vyatta-cfg-op-pppoe:
vyatta-cfg-op-pppoe depends on vyatta-cfg; however:
vyatta-cfg-op-pppoe depends on vyatta-op; however:
Package vyatta-op is not configured yet.
dpkg: error processing package vyatta-cfg-op-pppoe (--configure):
dpkg: dependency problems prevent configuration of vyatta-cfg-qos:
vyatta-cfg-qos depends on vyatta-cfg (>= 0.15.33); however:
dpkg: error processing package vyatta-cfg-qos (--configure):
dpkg: dependency problems prevent configuration of vyatta-cfg-quagga:
vyatta-cfg-quagga depends on vyatta-cfg (>= 0.18.56); however:
vyatta-cfg-quagga depends on vyatta-cfg-system (>= 0.19.125); however:
dpkg: error processing package vyatta-cfg-quagga (--configure):
dpkg: dependency problems prevent configuration of vyatta-cfg-vpn:
vyatta-cfg-vpn depends on vyatta-cfg (>= 0.15.33); however:
dpkg: error processing package vyatta-cfg-vpn (--configure):
dpkg: dependency problems prevent configuration of vyatta-cluster:
vyatta-cluster depends on vyatta-cfg (>= 0.15.33); however:
vyatta-cluster depends on vyatta-op; however:
dpkg: error processing package vyatta-cluster (--configure):
dpkg: dependency problems prevent configuration of vyatta-config-mgmt:
vyatta-config-mgmt depends on vyatta-cfg (>= 0.15.33); however:
vyatta-config-mgmt depends on vyatta-cfg-system; however:
vyatta-config-mgmt depends on vyatta-op; however:
dpkg: error processing package vyatta-config-mgmt (--configure):
dpkg: dependency problems prevent configuration of vyatta-conntrack:
vyatta-conntrack depends on vyatta-cfg-system; however:
vyatta-conntrack depends on vyatta-cfg; however:
vyatta-conntrack depends on vyatta-op; however:
dpkg: error processing package vyatta-conntrack (--configure):
Setting up vyatta-conntrack-sync (0.46+vyos2+current3) ...
dpkg: dependency problems prevent configuration of vyatta-eventwatch:
vyatta-eventwatch depends on vyatta-cfg; however:
dpkg: error processing package vyatta-eventwatch (--configure):
dpkg: dependency problems prevent configuration of vyatta-ipv6-rtradv:
vyatta-ipv6-rtradv depends on vyatta-cfg (>= 0.15.33); however:
dpkg: error processing package vyatta-ipv6-rtradv (--configure):
Setting up vyatta-lldp (0.25+vyos2+current1) ...
dpkg: dependency problems prevent configuration of vyatta-nat:
vyatta-nat depends on vyatta-cfg (>= 0.15.33); however:
vyatta-nat depends on vyatta-op; however:
dpkg: error processing package vyatta-nat (--configure):
dpkg: dependency problems prevent configuration of vyatta-netflow:
vyatta-netflow depends on vyatta-cfg; however:
vyatta-netflow depends on vyatta-cfg-system; however:
vyatta-netflow depends on vyatta-op; however:
dpkg: error processing package vyatta-netflow (--configure):
dpkg: dependency problems prevent configuration of vyatta-op-firewall:
vyatta-op-firewall depends on vyatta-op; however:
vyatta-op-firewall depends on vyatta-cfg (>= 0.101.0); however:
dpkg: error processing package vyatta-op-firewall (--configure):
dpkg: dependency problems prevent configuration of vyatta-op-qos:
vyatta-op-qos depends on vyatta-op; however:
dpkg: error processing package vyatta-op-qos (--configure):
dpkg: dependency problems prevent configuration of vyatta-op-quagga:
vyatta-op-quagga depends on vyatta-cfg; however:
vyatta-op-quagga depends on vyatta-op; however:
dpkg: error processing package vyatta-op-quagga (--configure):
dpkg: dependency problems prevent configuration of vyatta-op-vpn:
vyatta-op-vpn depends on vyatta-op; however:
vyatta-op-vpn depends on vyatta-cfg-vpn; however:
Package vyatta-cfg-vpn is not configured yet.
dpkg: error processing package vyatta-op-vpn (--configure):
dpkg: dependency problems prevent configuration of vyatta-openvpn:
vyatta-openvpn depends on vyatta-cfg (>= 0.15.33); however:
vyatta-openvpn depends on vyatta-op; however:
dpkg: error processing package vyatta-openvpn (--configure):
dpkg: dependency problems prevent configuration of vyatta-ravpn:
vyatta-ravpn depends on vyatta-cfg; however:
vyatta-ravpn depends on vyatta-op; however:
vyatta-ravpn depends on vyatta-cfg-vpn; however:
vyatta-ravpn depends on vyatta-op-vpn; however:
Package vyatta-op-vpn is not configured yet.
dpkg: error processing package vyatta-ravpn (--configure):
dpkg: dependency problems prevent configuration of vyatta-wanloadbalance:
vyatta-wanloadbalance depends on vyatta-cfg (>= 0.15.33); however:
vyatta-wanloadbalance depends on vyatta-cfg-firewall; however:
Package vyatta-cfg-firewall is not configured yet.
vyatta-wanloadbalance depends on vyatta-op; however:
dpkg: error processing package vyatta-wanloadbalance (--configure):
dpkg: dependency problems prevent configuration of vyatta-webproxy:
vyatta-webproxy depends on vyatta-cfg (>= 0.15.33); however:
vyatta-webproxy depends on vyatta-cfg-system; however:
vyatta-webproxy depends on vyatta-op; however:
dpkg: error processing package vyatta-webproxy (--configure):
dpkg: dependency problems prevent configuration of vyatta-wireless:
vyatta-wireless depends on vyatta-cfg (>= 0.15.33); however:
vyatta-wireless depends on vyatta-op; however:
vyatta-wireless depends on vyatta-cfg-system (>= 0.19.1); however:
dpkg: error processing package vyatta-wireless (--configure):
dpkg: dependency problems prevent configuration of vyatta-wirelessmodem:
vyatta-wirelessmodem depends on vyatta-cfg (>= 0.15.33); however:
vyatta-wirelessmodem depends on vyatta-op; however:
dpkg: error processing package vyatta-wirelessmodem (--configure):
dpkg: dependency problems prevent configuration of vyatta-zone:
vyatta-zone depends on vyatta-cfg; however:
vyatta-zone depends on vyatta-cfg-firewall; however:
dpkg: error processing package vyatta-zone (--configure):
Setting up vyos-intel-e1000e (3.4.2.4-0) ...
Setting up vyos-intel-i40e (2.9.21-0) ...
Setting up vyos-intel-i40evf (3.6.15-0) ...
Setting up vyos-intel-igb (5.3.5.22s-0) ...
Setting up vyos-intel-ixgbe (5.5.5-0) ...
Setting up vyos-intel-ixgbevf (4.5.3-0) ...
Setting up vyos-opennhrp (0.14.1-1+vyos2+current1) ...
dpkg: dependency problems prevent configuration of vyos-nhrp:
vyos-nhrp depends on vyatta-cfg-system; however:
vyos-nhrp depends on vyatta-cfg; however:
vyos-nhrp depends on vyatta-op; however:
dpkg: error processing package vyos-nhrp (--configure):
dpkg: dependency problems prevent configuration of vyos-world:
vyos-world depends on vyatta-cfg-system; however:
vyos-world depends on vyatta-op; however:
vyos-world depends on vyatta-config-mgmt; however:
Package vyatta-config-mgmt is not configured yet.
vyos-world depends on vyatta-cfg-firewall; however:
vyos-world depends on vyatta-op-firewall; however:
Package vyatta-op-firewall is not configured yet.
vyos-world depends on vyatta-cfg-op-pppoe; however:
Package vyatta-cfg-op-pppoe is not configured yet.
vyos-world depends on vyatta-cfg-qos; however:
Package vyatta-cfg-qos is not configured yet.
vyos-world depends on vyatta-op-qos; however:
Package vyatta-op-qos is not configured yet.
vyos-world depends on vyatta-cfg-quagga; however:
Package vyatta-cfg-quagga is not configured yet.
vyos-world depends on vyatta-op-quagga; however:
Package vyatta
dpkg: error processing package vyos-world (--configure):
Setting up zerofree (1.0.3-1) ...
Processing triggers for sgml-base (1.26+nmu4) ...
Setting up docutils-common (0.12+dfsg-1) ...
Setting up python-docutils (0.12+dfsg-1) ...
update-alternatives: using /usr/share/docutils/scripts/python2/rst-buildhtml to provide /usr/bin/rst-buildhtml (rst-buildhtml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2html to provide /usr/bin/rst2html (rst2html) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2latex to provide /usr/bin/rst2latex (rst2latex) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2man to provide /usr/bin/rst2man (rst2man) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2odt to provide /usr/bin/rst2odt (rst2odt) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2odt_prepstyles to provide /usr/bin/rst2odt_prepstyles (rst2odt_prepstyles) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2pseudoxml to provide /usr/bin/rst2pseudoxml (rst2pseudoxml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2s5 to provide /usr/bin/rst2s5 (rst2s5) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2xetex to provide /usr/bin/rst2xetex (rst2xetex) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rst2xml to provide /usr/bin/rst2xml (rst2xml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python2/rstpep2html to provide /usr/bin/rstpep2html (rstpep2html) in auto mode
Setting up python-wstools (0.4.3-2) ...
Setting up python-soappy (0.12.22-1) ...
Setting up python-debianbts (1.12) ...
Setting up python-reportbug (6.6.3+deb8u2) ...
Setting up reportbug (6.6.3+deb8u2) ...
Setting up liblwp-protocol-https-perl (6.06-2) ...
Setting up tasksel-data (3.31+deb8u1) ...
Setting up tasksel (3.31+deb8u1) ...
Setting up python3 (3.4.2-2) ...
Setting up python3-pkg-resources (5.5.1-1) ...
Setting up python3-hurry.filesize (0.9-1) ...
Setting up frr-pythontools (7.2-dev-20190608-00-g9fd5497-0) ...
Setting up libwww-perl (6.08-1) ...
Setting up libxml-parser-perl (2.41-3) ...
Setting up libxml-sax-expat-perl (0.40-2) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::Expat with priority 50...
update-perl-sax-parsers: Updating overall Perl SAX parser modules info file...
Replacing config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up libxml-simple-perl (2.20-1) ...
Setting up python3-bottle (0.12.7-1+deb8u2) ...
Setting up python3-isc-dhcp-leases (0.8.1-1) ...
Setting up python3-markupsafe (0.23-1+b1) ...
Setting up python3-jinja2 (2.9.4-1) ...
Setting up python3-netifaces (0.10.4-0.1) ...
Setting up python3-psutil (2.1.1-1+b1) ...
Setting up python3-pystache (0.5.4-2) ...
Setting up python3-six (1.8.0-1) ...
Setting up python3-tabulate (0.8.2-1) ...
Setting up python3-urllib3 (1.10.4-1) ...
Setting up python3-vici (5.7.2-1) ...
Setting up eventwatchd (0.2+vyos2+current1) ...
Setting up vyos-1x (1.3.0-16) ...
Setting up vyos-salt-minion (1.0.0) ...
Adding user minion to group frrvty
Adding user minion to group vyattacfg
Adding user minion to group sudo
Adding user minion to group adm
Adding user minion to group dip
Adding user minion to group disk
Adding user minion to group users
Setting up vyos-smoketest (1.0.0) ...
Setting up dh-python (1.20141111-2) ...
Processing triggers for systemd (215-17+deb8u13) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
Processing triggers for ca-certificates (20141019+deb8u4) ...
Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d....done.
Processing triggers for initramfs-tools (0.120+deb8u3) ...
update-initramfs: Generating /boot/initrd.img-4.19.54-amd64-vyos
W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
W: mdadm: no arrays defined in configuration file.
live-boot: core filesystems devices utils udev blockdev.
Processing triggers for python-support (1.0.15) ...
Processing triggers for dbus (1.8.22-0+deb8u2) ...
Errors were encountered while processing:
vyatta-cfg
vyatta-cfg-system
radius-shell
libpam-radius-auth
vyatta-cfg-firewall
vyatta-op
vyatta-cfg-op-pppoe
vyatta-cfg-qos
vyatta-cfg-quagga
vyatta-cfg-vpn
vyatta-cluster
vyatta-config-mgmt
vyatta-conntrack
vyatta-eventwatch
vyatta-ipv6-rtradv
vyatta-nat
vyatta-netflow
vyatta-op-firewall
vyatta-op-qos
vyatta-op-quagga
vyatta-op-vpn
vyatta-openvpn
vyatta-ravpn
vyatta-webproxy
vyatta-wireless
vyatta-zone
vyos-nhrp
vyos-world
E: Sub-process /usr/bin/dpkg returned an error code (1)
P: Saving caches...
Reading package lists...
Building dependency tree...
Reading state information...
vyos_bld@a0661e34e909:/vyos$
