Hi developers,
I tried to build VyOs for arm64,
Here is my steps
docker pull vyos/vyos-build:current-arm64
docker run --rm -it \
-v "$(pwd)":/vyos \
-w /vyos --privileged --sysctl net.ipv6.conf.lo.disable_ipv6=0 \
-e GOSU_UID=$(id -u) -e GOSU_GID=$(id -g) \
vyos/vyos-build:current-arm64 bash
VYOS_BUILD_FLAVOR=data/generic-arm64.json ./configure --architecture arm64
sudo make iso
The build process stop :
I: Validating liblzma5 5.2.5-2
I: Validating zlib1g 1:1.2.11.dfsg-2
P: If the following stage fails, the most likely cause of the problem is with your mirror configuration or a caching proxy.
P: Running debootstrap...
/usr/share/debootstrap/functions: line 1578: /vyos/build/chroot/test-dev-null: Permission denied
E: Cannot install into target '/vyos/build/chroot' mounted with noexec or nodev
make: *** [Makefile:32: iso] Error 1
vyos_bld@a4ab95cb476b:/vyos$
I checked “/usr/share/debootstrap/functions” line 1578 in docker.
It failed cause Permission denied to “echo test > test-dev-null”
Any step I did wrong or any configuration need to fix ?
Thank you.
