hi there,
i followed the steps and could not build the iso image. please see:
udevadm_test: MATCHIFTYPE=1
udevadm_test: MATCHDEVID=0x0
udevadm_test: run: 'net.agent'
run_command: calling: test
udevadm_test: version 164
add_matching_files: unable to open '/dev/.udev/rules.d': No such file or directory
parse_file: reading '/lib/udev/rules.d/50-udev-default.rules' as rules file
parse_file: reading '/lib/udev/rules.d/55-dm.rules' as rules file
add_rule: NAME="" is ignored, because udev will not delete any device nodes, please remove it from /lib/udev/rules.d/55-dm.rules:57
parse_file: reading '/lib/udev/rules.d/60-fuse-utils.rules' as rules file
util_lookup_group: specified group 'fuse' unknown
parse_file: reading '/lib/udev/rules.d/60-gnupg.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-alsa.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-input.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-serial.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-storage-dm.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-storage-tape.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-storage.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-v4l.rules' as rules file
parse_file: reading '/lib/udev/rules.d/61-mobile-action.rules' as rules file
parse_file: reading '/lib/udev/rules.d/64-md-raid.rules' as rules file
parse_file: reading '/lib/udev/rules.d/65-vyatta-net.rules' as rules file
parse_file: reading '/lib/udev/rules.d/70-acl.rules' as rules file
parse_file: reading '/lib/udev/rules.d/70-hid2hci.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-cd-aliases-generator.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-net-description.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-persistent-net-generator.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-probe_mtd.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-tty-description.rules' as rules file
parse_file: reading '/lib/udev/rules.d/78-sound-card.rules' as rules file
parse_file: reading '/lib/udev/rules.d/79-fstab_import.rules' as rules file
parse_file: reading '/lib/udev/rules.d/80-drivers.rules' as rules file
parse_file: reading '/lib/udev/rules.d/85-hwclock.rules' as rules file
parse_file: reading '/lib/udev/rules.d/91-permissions.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-keyboard-force-release.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-keymap.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-udev-late.rules' as rules file
udev_rules_new: rules use 25992 bytes tokens (2166 * 12 bytes), 15871 bytes buffer
udev_rules_new: temporary index used 17100 bytes (855 * 20 bytes)
udev_device_new_from_syspath: device 0x41c806f8 has devpath '/devices/virtual/net/lo'
udev_device_new_from_syspath: device 0x41c80860 has devpath '/devices/virtual/net/lo'
udev_rules_apply_to_event: RUN 'net.agent' /lib/udev/rules.d/80-drivers.rules:52
udevadm_test: UDEV_LOG=6
udevadm_test: DEVPATH=/devices/virtual/net/lo
udevadm_test: INTERFACE=lo
udevadm_test: IFINDEX=1
udevadm_test: ACTION=add
udevadm_test: SUBSYSTEM=net
udev_device_new_from_syspath: device 0x407c56f8 has devpath '/devices/virtual/net/pan0'
udev_device_new_from_syspath: device 0x407c5868 has devpath '/devices/virtual/net/pan0'
udevadm_test: DEVPATH=/devices/virtual/net/pan0
udevadm_test: DEVTYPE=bridge
udevadm_test: INTERFACE=pan0
udevadm_test: IFINDEX=3
A chroot environment has been detected, udev not started.
Setting up squid-langpack (20100628-1) ...
Setting up libmnl0 (1.0.3-5+vyos1+helium1) ...
Setting up rsyslog (4.6.4-2) ...
All runlevel operations denied by policy
invoke-rc.d: policy-rc.d denied execution of start.
Setting up installation-report (2.44) ...
update-rc.d: using dependency based boot sequencing
Setting up cpio (2.11-4) ...
update-alternatives: using /bin/mt-gnu to provide /bin/mt (mt) in auto mode.
Setting up libpcsclite1 (1.5.5-4) ...
Setting up iputils-arping (3:20100418-3) ...
Setting up ipvsadm (1:1.25.clean-1) ...
Setting up ca-certificates (20090814+nmu3squeeze1) ...
Updating certificates in /etc/ssl/certs... WARNING: Skipping duplicate certificate ca-certificates.crt
140 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d....done.
Setting up vim-tiny (2:7.2.445+hg~cb94c42c0e1a-1) ...
update-alternatives: using /usr/bin/vim.tiny to provide /usr/bin/rview (rview) in auto mode.
update-alternatives: using /usr/bin/vim.tiny to provide /usr/bin/vi (vi) in auto mode.
update-alternatives: using /usr/bin/vim.tiny to provide /usr/bin/view (view) in auto mode.
update-alternatives: using /usr/bin/vim.tiny to provide /usr/bin/ex (ex) in auto mode.
Setting up libnetfilter-cthelper (1.0.1-4+vyos1+helium1) ...
Setting up libnet1 (1.1.4-2) ...
Setting up less (436-1) ...
Setting up libglib2.0-0 (2.24.2-1) ...
Setting up libcap2 (1:2.19-3+vyos1+helium1) ...
Setting up libnfnetlink0 (1.0.0-1) ...
Setting up libwrap0 (7.6.q-19) ...
Setting up lsof (4.81.dfsg.1-1) ...
Setting up initramfs-tools (0.99.0+vyos1+helium1) ...
update-initramfs: deferring update (trigger activated)
Setting up laptop-detect (0.13.7) ...
Setting up man-db (2.5.7-8) ...
Building database of manual pages ...
Setting up libgcrypt11 (1.4.5-2+squeeze1) ...
Setting up squid3-common (3.1.6-1.2+squeeze3) ...
Setting up wpasupplicant (0.6.10-2.1) ...
Setting up python-minimal (2.6.6-3+squeeze7) ...
Setting up whois (5.0.10) ...
Setting up vyatta-dhcp3-relay (4.1.8+vyos1+helium1) ...
Generating /etc/default/dhcp3-relay...
Setting up jnettop (0.12.0-4) ...
Setting up cpufrequtils (007-2) ...
Setting up iw (0.9.19-1) ...
Setting up libisc62 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up libxslt1.1 (1.1.26-6+squeeze3) ...
Setting up libk5crypto3 (1.8.3+dfsg-4squeeze6) ...
Setting up dnsmasq-base (2.55-2+b1) ...
Setting up vyatta-dhcp3-client (4.1.8+vyos1+helium1) ...
Setting up libisccc60 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up iftop (0.17-16) ...
Setting up xl2tpd (1.2.7+dfsg-1) ...
Setting up ifupdown (0.6.10) ...
df: Warning: cannot read table of mounted file systems: No such file or directory
ifupdown.postinst: Warning: No 'iface lo' definition found in /etc/network/interfaces
ifupdown.postinst: Warning: No 'auto lo' statement found in /etc/network/interfaces
Setting up libnetfilter-queue1 (0.0.17-6+hyos1+helium1) ...
Setting up live-initramfs (1.157.1-1+vyos1+helium1) ...
Setting up libcap2-bin (1:2.19-3+vyos1+helium1) ...
Setting up python2.6 (2.6.6-8+b1) ...
Setting up console-setup (1.68+squeeze2) ...
Setting up libnetfilter-cttimeout (1.0.0-3+vyos1+helium1) ...
Setting up ppp (2.4.5-4) ...
Setting up logrotate (3.7.8-6) ...
Setting up iproute (20120801+vyos1+helium1) ...
Setting up liblwres60 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up libcluster-glue (1.0.6-1) ...
Setting up pppoe (3.8-3) ...
Setting up kbd (1.15.2-2) ...
Setting up netplug (1.2.9.1-2+vyos1+helium1) ...
Setting up libnetfilter-conntrack3 (1.0.0-1+vyos1+helium1) ...
Setting up libsensors4 (1:3.1.2-6) ...
Setting up dnsmasq (2.55-2) ...
Setting up squidclient (3.1.6-1.2+squeeze3) ...
Setting up acpi-support-base (0.137-5) ...
invoke-rc.d: policy-rc.d denied execution of restart.
Setting up libgnutls26 (2.8.6-1+squeeze2) ...
Setting up xsltproc (1.1.26-6+squeeze3) ...
Setting up mdadm (3.1.4-1+8efb9d1+squeeze1) ...
W: mdadm: failed to load MD subsystem.
Generating mdadm.conf... done (failed to scan arrays; /proc probably not mounted).
Setting up mgetty (1.1.36-1.6) ...
Setting up pptpd (1.3.4-3) ...
Setting up libldap-2.4-2 (2.4.23-7.3) ...
Setting up fuse-utils (2.8.4-1.1) ...
creating fuse group...
Adding group `fuse' (GID 109) ...
Done.
udev active, skipping device node creation.
Setting up ntpdate (1:4.2.6.p2+dfsg-1+vyos1+helium1) ...
Setting up libopenhpi2 (2.14.1-1) ...
Setting up ssmtp (2.64-4) ...
Setting up iptables (1.4.10+vyos1+helium1) ...
Setting up unionfs-fuse (0.24-2.1~bpo60+1) ...
Setting up linux-image-3.3.8-1-586-vyos (3.3.8-1+vyos1+helium1) ...
Running depmod.
Finding valid ramdisk creators.
Using mkinitramfs-kpkg to build the ramdisk.
Deprecation WARNING: use update-initramfs(8)
W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
W: mkconf: MD subsystem is not loaded, thus I cannot scan for arrays.
W: mdadm: failed to auto-generate temporary mdadm.conf file.
W: mdadm: no configuration file available.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.3.8-1-586-vyos /boot/vmlinuz-3.3.8-1-586-vyos
Setting up libkrb5-3 (1.8.3+dfsg-4squeeze6) ...
Setting up libssh2-1 (1.2.6-1) ...
Setting up vlan (1.9-3) ...
Setting up libgssapi-krb5-2 (1.8.3+dfsg-4squeeze6) ...
Setting up libheartbeat2 (1:3.0.3-2) ...
Setting up ipset (6.9-1+vyos1+helium1) ...
Setting up nfct (1:1.0.1-3+vyos1+helium4) ...
Setting up console-common (0.7.85) ...
Looking for keymap to install:
NONE
Setting up python (2.6.6-3+squeeze7) ...
Setting up libdns69 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up pmacct (0.14.0+vyos1+helium1) ...
Setting up conntrack-helpers (1:1.0.1-3+vyos1+helium4) ...
Setting up libsnmp15 (5.7.2+vyos1+helium1) ...
Setting up vyatta-keepalived (1.2.2-1+vyos1+helium1) ...
update-rc.d: warning: vyatta-keepalived start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (none)
Setting up ntp (1:4.2.6.p2+dfsg-1+vyos1+helium1) ...
Setting up conntrackd (1:1.0.1-3+vyos1+helium4) ...
Setting up libcurl3 (7.21.0-2.1+squeeze4) ...
Setting up conntrack (1:1.0.1-3+vyos1+helium4) ...
Setting up ipsec-tools (1:0.7.3-12) ...
Setting up open-vm-modules-3.3.8-1-586-vyos (1:9.0.0+vyos1+helium1) ...
Setting up python-central (0.6.16+nmu1) ...
Setting up snmpd (5.7.2+vyos1+helium1) ...
Setting up openvpn-blacklist (0.4) ...
Setting up wireshark-common (1.2.11-6+squeeze10) ...
Setting up openssh-client (1:5.5p1-6+squeeze3) ...
Setting up open-vm-tools (1:9.0.0+vyos1+helium1) ...
update-initramfs: Generating /boot/initrd.img-3.3.8-1-586-vyos
Setting up squid3 (3.1.6-1.2+squeeze3) ...
Creating Squid HTTP proxy 3.x spool directory structure
2014/05/12 23:51:35| Creating Swap Directories
Setting up vyatta-quagga (0.99.20.1-13+vyos1+helium1) ...
Setting up libisccfg62 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up vyatta-dhcp3-server (4.1.8+vyos1+helium1) ...
Generating /etc/default/dhcp3-server...
Setting up openssl-blacklist (0.5-2) ...
Setting up libbind9-60 (1:9.7.3.dfsg-1~squeeze11) ...
Setting up libcurl3-gnutls (7.21.0-2.1+squeeze4) ...
Setting up apt-transport-https (0.8.10.3+squeeze1) ...
Setting up curl (7.21.0-2.1+squeeze4) ...
Setting up snmp (5.7.2+vyos1+helium1) ...
Setting up bind9-host (1:9.7.3.dfsg-1~squeeze11) ...
Setting up openvpn (2.1.3-2+squeeze1) ...
invoke-rc.d: action cond-restart is unknown, but proceeding anyway.
invoke-rc.d: policy-rc.d denied execution of cond-restart.
Setting up openssh-server (1:5.5p1-6+squeeze3) ...
Creating SSH2 RSA key; this may take some time ...
Creating SSH2 DSA key; this may take some time ...
Setting up tshark (1.2.11-6+squeeze10) ...
Setting up ssh (1:5.5p1-6+squeeze3) ...
Setting up host (1:9.7.3.dfsg-1~squeeze11) ...
Setting up perl-modules (5.10.1-17squeeze6) ...
Setting up strongswan-ikev2 (4.5.2-1.1-bpo60+vyos1+helium1) ...
Setting up strongswan-ikev1 (4.5.2-1.1-bpo60+vyos1+helium1) ...
Setting up tasksel-data (2.88) ...
Setting up perl (5.10.1-17squeeze6) ...
update-alternatives: using /usr/bin/prename to provide /usr/bin/rename (rename) in auto mode.
Setting up vyatta-config-migrate (0.13.65+vyos1+helium1) ...
Setting up libwant-perl (0.18-2) ...
Setting up libhtml-tagset-perl (3.20-2) ...
Setting up libfile-slurp-perl (9999.13-1) ...
Setting up libsocket6-perl (0.23-1) ...
Setting up vyatta-lldp (0.25+vyos1+helium1) ...
Setting up libfile-sync-perl (0.09-4+b1) ...
Setting up libsort-versions-perl (1.5-4) ...
Setting up vyatta-conntrack-sync (0.46+vyos1+helium1) ...
Setting up strongswan-starter (4.5.2-1.1-bpo60+vyos1+helium1) ...
Disabling opportunistic encryption (OE) in config file ... All runlevel operations denied by policy
Setting up libnetaddr-ip-perl (4.028+dfsg-1) ...
Setting up strongswan (4.5.2-1.1-bpo60+vyos1+helium1) ...
Setting up ddclient (3.8.0-11.3) ...
Setting up libtimedate-perl (1.2000-1) ...
Setting up libtree-simple-perl (1.18-1) ...
Setting up liburi-perl (1.54-2) ...
Setting up tasksel (2.88) ...
Setting up cluster-glue (1.0.6-1) ...
Setting up libterm-readkey-perl (2.30-4) ...
Setting up libxml-namespacesupport-perl (1.09-3) ...
Setting up libterm-readline-perl-perl (1.0303-1) ...
Setting up libsnmp-perl (5.7.2+vyos1+helium1) ...
Setting up libnet-ssleay-perl (1.36-1) ...
Setting up libio-socket-ssl-perl (1.33-1+squeeze1) ...
Setting up libhtml-parser-perl (3.66-1) ...
Setting up libvyatta-cfg1 (0.102.0+vyos1+helium3) ...
Setting up libio-prompt-perl (0.997001-1) ...
Setting up cluster-agents (1:1.0.3-3.1) ...
Setting up heartbeat (1:3.0.3-2) ...
Setting up libxml-sax-perl (0.96+dfsg-2) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::SAX::PurePerl with priority 10...
update-perl-sax-parsers: Updating overall Perl SAX parser modules info file...
Creating config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up lighttpd (1.4.28-2+squeeze1.3) ...
Setting up libhtml-tree-perl (3.23-2) ...
Setting up vyatta-cfg (0.102.0+vyos1+helium3) ...
Setting up vyatta-cfg-dhcp-server (0.12.36+vyos1+helium3) ...
Setting up vyatta-cfg-dhcp-relay (0.11.0+vyos1+helium1) ...
Setting up libwww-perl (5.836-1) ...
Setting up squidguard (1.4.0+vyos1+helium1) ...
Setting up vyatta-cfg-qos (0.15.42+vyos1+helium3) ...
Setting up vyatta-cfg-vpn (0.12.105+vyos1+helium1) ...
Setting up libxml-libxml-perl (1.70.ds-1) ...
update-perl-sax-parsers: Registering Perl SAX parser XML::LibXML::SAX::Parser with priority 50...
update-perl-sax-parsers: Registering Perl SAX parser XML::LibXML::SAX with priority 50...
Replacing config file /etc/perl/XML/SAX/ParserDetails.ini with new version
Setting up vyatta-cfg-system (999.dev) ...
Adding system user `tss' (UID 109) ...
Adding new group `tss' (GID 114) ...
Adding new user `tss' (UID 109) with group `tss' ...
Creating home directory `/var/lib/tpm' ...
Failed to set capabilities on file `/sbin/iptables-multi' (No such file or directory)
usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
Note <filename> must be a regular (non-symlink) file.
Failed to set capabilities on file `/sbin/ip6tables-multi' (No such file or directory)
Creating SSH1 key; this may take some time ...
grep: /etc/modprobe.d/blacklist-sound.conf: No such file or directory
Setting up libxml-simple-perl (2.18-3) ...
Setting up vyatta-ipv6-rtradv (0.38+vyos1+helium1) ...
Setting up vyatta-op (0.14.0+vyos1+helium5) ...
Setting up vyatta-cfg-quagga (0.19.0+vyos1+helium5) ...
Setting up vyatta-nat (0.13.0+vyos1+helium2) ...
Setting up vyatta-openvpn (0.2.60+vyos1+helium2) ...
Setting up vyatta-op-qos (0.12.27+vyos1+helium1) ...
Setting up vyatta-config-mgmt (0.34+vyos1+helium1) ...
Setting up vyatta-cluster (0.11.25+vyos1+helium1) ...
Setting up vyatta-op-vpn (0.14.0+vyos1+helium1) ...
Setting up vyatta-cfg-firewall (0.13.91+vyos1+helium3) ...
Setting up vyatta-conntrack (0.54+vyos1+helium1) ...
Setting up vyatta-webgui (0.2.13-101+vyos1+helium1) ...
Setting up vyatta-cron (1.0.3+vyos1+helium1) ...
Setting up vyatta-cfg-op-pppoe (0.11.20+vyos1+helium1) ...
update-rc.d: warning: vyatta-pppoe start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (1 2 3)
update-rc.d: warning: vyatta-pppoe stop runlevel arguments (0 1 6) do not match LSB Default-Stop values (none)
Setting up vyatta-ravpn (0.12.44+vyos1+helium3) ...
Setting up vyatta-wirelessmodem (0.1.24+vyos1+helium1) ...
Setting up vyatta-op-firewall (0.11.0+vyos1+helium1) ...
Setting up vyatta-op-dhcp-server (0.14.0+vyos1+helium3) ...
Setting up vyatta-netflow (0.42+vyos1+helium1) ...
Setting up vyatta-webproxy (0.2.110+vyos1+helium2) ...
Setting up vyatta-op-quagga (0.11.34+vyos1+helium1) ...
Setting up vyatta-zone (0.15+vyos1+helium1) ...
Setting up vyatta-wireless (0.3.41+vyos1+helium1) ...
Setting up vyatta-wanloadbalance (0.13.68+vyos1+helium1) ...
Processing triggers for initramfs-tools ...
xargs: aptitude: exited with status 255; aborting
E: chroot build failed
root@debian6:/home/user/build-iso#
