I want build my 1.3.2 with custom kernel.
1. git clone -b 1.3.2 https://github.com/vyos/vyos-build
2. follow the steps here https://docs.vyos.io/en/equuleus/contributing/build-vyos.html
but I can’t get iso built. because make iso will install newer version kernel on it. How can I make it work? Thanks
there are many ways to build-iso , I think the easiest using a container to build from source-code :
https://docs.vyos.io/en/equuleus/contributing/build-vyos.html#build-iso
at least with this , you should have an ISO to install on VM , also if you are able to get this ISO, same container can be used to create a new ISO with different kernel .
:Build VyOS — VyOS 1.3.x (equuleus) documentation
These are error log from build process
Some packages could not be installed. This may mean that you have
vyos-1x-vmware : Depends: vyos-1x but it is not going to be installed
vyos-world : Depends: vyos-1x but it is not going to be installed
P: Saving caches...
Reading package lists...
Building dependency tree...
Reading state information...
make: *** [Makefile:32: iso] Error 1
Error: Process completed with exit code 2.
