ackema
1
Dear all,
According to vyos-build/Makefile, make iso will clean(rm -rf all) and download(live build). It takes quite a long time.
How can I make iso without clean and download?
And how can I make iso with my own default config, custom deb and modified code in local disk?
Is there any tutorial about these questions?
Thanks.
it depends on your environment , but it should take a long time . in our documentation ,there is a step by step how to build an iso.
https://docs.vyos.io/en/latest/contributing/build-vyos.html
regards
ackema
3
Thanks
Do you have any mirrors in China‘s Mainland?
Or can I set up a local mirror for myself?
ackema
4
Can anybody help me?
I replaced http://deb.debian.org/debian with https://mirrors.tuna.tsinghua.edu.cn/debian in build/build-config.json.
However lb build still get a lot of files from http://deb.debian.org/debian
Following error comes out again and again:
Ign:16 http://deb.debian.org/debian buster/main amd64 Packages
Get:16 http://deb.debian.org/debian buster/main amd64 Packages [10.7 MB]
Err:16 http://deb.debian.org/debian buster/main amd64 Packages
Connection timed out [IP: 151.101.110.132 80]
Fetched 30.3 MB in 20min 16s (24.9 kB/s)
Reading package lists...
E: Failed to fetch http://deb.debian.org/debian/dists/buster/main/binary-amd64/Packages Connection timed out [IP: 151.101.110.132 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
P: Saving caches...
Building dependency tree...
Del vyos-1x 1.4dev0-2321-gc4d38948 [1418 kB]
Del bash-completion 1:2.8-6 [208 kB]
Del vyos-1x-smoketest 1.4dev0-2321-gc4d38948 [194 kB]
Del vyos-1x-vmware 1.4dev0-2321-gc4d38948 [3900 B]
make: *** [Makefile:32:iso] 错误 1
root@debian:/home/vyos/vyos-build#
ackema
5
How can i speed up the make iso process? Thanks!
I have replace mirror in build/build-config.json like this:
root@debian:/home/vyos/vyos-build# cat build/build-config.json
"architecture": "amd64",
"bootloaders": "syslinux,grub-efi",
"build_by": "root@debian",
"build_comment": "",
"build_dir": "build",
"build_type": "development",
"custom_apt_entry": [
"deb [arch=amd64] https://repo.saltproject.io/py3/debian/10/amd64/3003 buster main",
"deb [arch=amd64] http://repo.powerdns.com/debian bullseye-rec-45 main",
"deb [arch=amd64] https://repos.influxdata.com/debian bullseye stable"
"custom_apt_key": null,
"custom_package": [],
"debian_mirror": "http://mirrors.163.com/debian",
"debian_security_mirror": "http://mirrors.163.com/debian",
"debug": false,
"distribution": "bullseye",
"kernel_flavor": "amd64-vyos",
"kernel_version": "5.10.104",
"pbuilder_config": "build/pbuilderrc",
"pbuilder_debian_mirror": "http://mirrors.163.com/debian",
"release_train": "sagitta",
"version": null,
"vyos_branch": "current",
"vyos_mirror": "http://dev.packages.vyos.net/repositories/current"
However, make iso still get most of the files from original mirrors:
P: Configuring file /etc/apt/apt.conf
[2022-03-11 10:51:38] lb bootstrap_archives
P: Configuring file /etc/apt/sources.list
Get:1 http://mirrors.163.com/debian bullseye InRelease [116 kB]
Get:2 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Get:3 http://deb.debian.org/debian buster InRelease [122 kB]
Get:4 http://dev.packages.vyos.net/repositories/current current InRelease [3544 B]
Get:5 http://repo.powerdns.com/debian bullseye-rec-45 InRelease [1798 B]
Get:6 https://repos.influxdata.com/debian bullseye InRelease [4739 B]
Get:7 http://dev.packages.vyos.net/repositories/current current/main amd64 Packages [45.1 kB]
Get:8 http://mirrors.163.com/debian bullseye-updates InRelease [39.4 kB]
Get:9 https://repo.saltproject.io/py3/debian/10/amd64/3003 buster InRelease [2848 B]
Get:10 https://repos.influxdata.com/debian bullseye/stable amd64 Packages [1267 B]
Get:11 http://mirrors.163.com/debian bullseye/main Sources [8626 kB]
Get:12 https://repo.saltproject.io/py3/debian/10/amd64/3003 buster/main amd64 Packages [2911 B]
Get:13 http://repo.powerdns.com/debian bullseye-rec-45/main amd64 Packages [846 B]
Get:14 http://security.debian.org/debian-security buster/updates/main amd64 Packages [317 kB]
Get:15 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:16 http://deb.debian.org/debian buster/main amd64 Packages [7906 kB]
Get:17 http://mirrors.163.com/debian bullseye/contrib Sources [43.0 kB]
Get:18 http://mirrors.163.com/debian bullseye/non-free Sources [80.5 kB]
Get:19 http://mirrors.163.com/debian bullseye/main amd64 Packages [8183 kB]
Get:20 http://security.debian.org/debian-security buster/updates/main Translation-en [172 kB]
Get:21 http://security.debian.org/debian-security buster/updates/non-free amd64 Packages [556 B]
Get:22 http://security.debian.org/debian-security buster/updates/non-free Translation-en [344 B]
Get:23 http://mirrors.163.com/debian bullseye/main Translation-en [6243 kB]
Get:24 http://mirrors.163.com/debian bullseye/contrib amd64 Packages [50.5 kB]
Get:25 http://mirrors.163.com/debian bullseye/contrib Translation-en [46.9 kB]
Get:26 http://mirrors.163.com/debian bullseye/non-free amd64 Packages [93.8 kB]
Get:27 http://mirrors.163.com/debian bullseye/non-free Translation-en [91.5 kB]
Get:28 http://mirrors.163.com/debian bullseye-updates/main Sources [1868 B]
Get:29 http://mirrors.163.com/debian bullseye-updates/main amd64 Packages [2596 B]
Get:30 http://mirrors.163.com/debian bullseye-updates/main Translation-en [2343 B]
Get:31 http://deb.debian.org/debian buster/main Translation-en [5968 kB]
Get:32 http://deb.debian.org/debian buster/non-free amd64 Packages [87.7 kB]
Get:33 http://deb.debian.org/debian buster/non-free Translation-en [88.8 kB]
Get:34 http://deb.debian.org/debian buster-updates/main amd64 Packages [8792 B]
Get:35 http://deb.debian.org/debian buster-updates/main Translation-en [6915 B]
ackema
6
close this question.
I succed to make iso on a server located in America.
So I think my problem was caused by network environment.
Thinks again!
