Posted here as well
So, first, my budget is capped at exactly $300 for the router. Second, I’d like to future-proof my build/purchase. Third, I live in India, this is an important factor as it has to do with high import taxes.
Ideal requirements:
- 10G Ethernet (4-6 ports)
- SFP+/QSFP+ (whichever is more suited towards the budget)
- Decent CPU to be able to route 3G WAN bandwidth
Realistic Requirements:
- 1G Ethernet (6 ports)
My planned futureproof setup for the above router:
3 WANs, each 1G (or 2 WANs 1G, one WAN 100-500M) - All load-balanced (similar to PCC or Nth on RouterOS)
If we have 10G ethernet and/or SFP+/QSFP+, then I’d simply use those to connect to a 10G switch.
If we don’t have 10G ethernet and/or SFP+/QSFP+, then I’d use three 1G ethernet each for each WAN, then simply Channel bond the remaining 3 ethernet ports to give 3G link rate and hook those up to three bonded ports on a 10G switch
There are lots of boxes out there for sure, but most are some Chinese brands where I can’t get service for in my country, so the best box (with assured service/warranty) that I found is this
Of course, if I build from scratch, then the servicing issue would be different/solved.
