I builded a dev image to do some test on different virtualization platform, I saw that “xe-guest-utilities” it’s deprecated and new package is “xen-guest-agent”. I fixed in this way:
diff --git a/data/build-flavors/xcpng.toml b/data/build-flavors/xcpng.toml
index 3a04177..8836ed5 100644
--- a/data/build-flavors/xcpng.toml
+++ b/data/build-flavors/xcpng.toml
@@ -3,4 +3,4 @@
image_format = "iso"
# Include these packages in the image
-packages = ["xe-guest-utilities"]
+packages = ["xen-guest-agent"]
It also doesnt exist in the bookworm repos according to:
Also this:
The xen-guest-agent repository will be the new upstream for the Xen agent running in Linux/BSDs (POSIX) VMs.
I interpret above as xen-guest-agent might replace xe-guest-utilities but havent done so yet?
As in not ready for production use or is there some official info elsewhere confirming that xen-guest-agent now have replaced xe-guest-utilities and that xe-guest-utilities is now deprecated?
I found the workaround because during the build i saw that:
[2024-11-24 09:55:53] lb chroot_install-packages install
P: Begin installing packages (install pass)...
Reading package lists... Done
Package xe-guest-utilities is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
xen-guest-agent
E: Package 'xe-guest-utilities' has no installation candidate
P: Saving caches...
File "/vyos/./build-vyos-image", line 656, in <module>
cmd("lb build 2>&1")
File "/vyos/scripts/image-build/utils.py", line 84, in cmd
raise OSError(f"Command '{command}' failed")
OSError: Command 'lb build 2>&1' failed
vyos_bld@03d2fa539ade:/vyos$
