Can not establish SSH connection from vyos device through VRF interface
Hi all,
We’ve noticed that there is an unexpected issue when trying to perform an ssh/scp from vyos to other destination when being routed through VRF.
In our scenario we have vyos with eth0 in network_A, with vrf for management. We’ve also have 2 other interfaces for lan/wan. We want to ssh/scp from vyos management to other server in network_B, for that we’ve configured a static route. We can ping the other host, and performing a tcpdump we capture the SYN and SYN ACK packets, but after that, the vyos sends a RESET and is not possible to establish the connection.
Is there a kind of bug for this situation regarding VRF and handshake? It seems that there is no routing issue at all…
here more details regarding configuration:
set interfaces ethernet eth0 vrf 'management'
set protocols static route DESTINATION_IP next-hop VRF_GATEWAY next-hop-vrf 'management'
set protocols vrf management static route 0.0.0.0/0 next-hop VRF_GATEWAY
set service ssh vrf 'management'
set vrf name management table '1'
and the tcpdump performed in vyos eth0:
10:37:54.429608 IP VYOS_VRF_IP.36294 > DESTINATION_IP.22: Flags [S], seq 3067936304, win 64240, options [mss 1460,sackOK,TS val 2474142607 ecr 0,nop,wscale 7], length 0
10:37:54.463050 IP DESTINATION_IP.22 > VYOS_VRF_IP.36294: Flags [S.], seq 1420136728, ack 3067936305, win 28960, options [mss 1460,sackOK,TS val 1310452683 ecr 2474142607,nop,wscale 7], length 0
10:37:54.463076 IP VYOS_VRF_IP.36294 > DESTINATION_IP.22: Flags [R], seq 3067936305, win 0, length 0
Many thanks and regards
I have my VRF config isolated from each other as in no VRF leaking (your “set protocols static … next-hop VRF…” is a VRF leak setup).
Here are the current config I use in the lab:
set interfaces ethernet eth0 address '192.168.56.2/24'
set interfaces ethernet eth0 description 'MGMT'
set interfaces ethernet eth0 hw-id '<REMOVED>'
set interfaces ethernet eth0 ip arp-cache-timeout '240'
set interfaces ethernet eth0 offload lro
set interfaces ethernet eth0 offload rfs
set interfaces ethernet eth0 offload rps
set interfaces ethernet eth0 ring-buffer rx '4096'
set interfaces ethernet eth0 ring-buffer tx '4096'
set interfaces ethernet eth0 vrf 'VRF_MGMT'
set interfaces ethernet eth1 address '192.168.1.2/24'
set interfaces ethernet eth1 description 'WAN'
set interfaces ethernet eth1 hw-id '<REMOVED>'
set interfaces ethernet eth1 ip arp-cache-timeout '240'
set interfaces ethernet eth1 offload lro
set interfaces ethernet eth1 offload rfs
set interfaces ethernet eth1 offload rps
set interfaces ethernet eth1 ring-buffer rx '4096'
set interfaces ethernet eth1 ring-buffer tx '4096'
set interfaces ethernet eth1 vrf 'VRF_TEST'
set service ssh access-control allow user 'vyos'
set service ssh ciphers 'aes256-gcm@openssh.com'
set service ssh dynamic-protection allow-from '192.168.0.0/16'
set service ssh dynamic-protection block-time '60'
set service ssh dynamic-protection detect-time '3600'
set service ssh dynamic-protection threshold '10'
set service ssh listen-address '192.168.56.2'
set service ssh mac 'hmac-sha2-512'
set service ssh rekey data '1024'
set service ssh rekey time '60'
set service ssh vrf 'VRF_MGMT'
set system option http-client source-interface 'eth1'
set system option ssh-client source-interface 'eth1'
set vrf name VRF_MGMT description 'Management'
set vrf name VRF_MGMT table '100'
set vrf name VRF_MGMT vni '10000100'
set vrf name VRF_TEST description 'Test'
set vrf name VRF_TEST protocols static route 0.0.0.0/0 next-hop 192.168.1.254 distance '1'
set vrf name VRF_TEST table '101'
set vrf name VRF_TEST vni '10000101'
Then to select which VRF to use for outgoing SSH connections from the VyOS box I use this script as example (placed in /config/custom/config_backup.sh):
#!/bin/sh
# Script debugging
set -x
# Set variables
NOW=$(date +"%y%m%d_%H%M")
SRCFILE=/config/config.boot
DSTFILE=/home/username/vyos/config_${NOW}.boot
USER=username
SERVER=192.168.1.100
VRF=VRF_TEST
# Perform stuff
ip vrf exec ${VRF} scp ${SRCFILE} ${USER}@${SERVER}:${DSTFILE}
The magic is the line at the bottom (example if you from CLI want to SSH to a different host on the VRF_MGMT):
ip vrf exec VRF_MGMT ssh user@host
Hi @Apachez ,
Many thanks for your smart solution, it definitively works!
Kind regards!
