before, without a problem, installed on Motherbord GABYTE GA-C1037UN by a drive for USB. And now the motherboard is not more available, and I bought another one GIGABYTE GA-N3050N-D3H! And for some reason I can not establish an error occurs.
BIOS is updated and set the LEGACY mode. Through SATA-drive normally installed, it is the image okay.
what could be wrong?
This command does not produce anything : “cat /live.log”
Problem:
“[color=#ff0000][size=small][font=Verdana, Arial, Helvetica, sans-serif]/bin/sh: Can’t access tty; job control turned off[/font][/size][/color]”
Picture link:
Yes, well, I downloaded and create an installation USB flash drive! The image of the new Vyos(vyos-999.201609230235) has a different menu, it has a point of installation, but nothing happens when I press. So it should be?
I have problem like this on both version 1.1.8 & 1.1.7. If i use image in http://dev.packages.vyos.net/iso/current/amd64/, i can install VyOS in my system. But i found some bug in image still developing so i want to use stable version. How i can fix it? Thank you & Sorry for my English
