I am using the 20171107 build as I can;t get the 1.17 or the 1.1.8 RC2 to load on my bare metal.
OK I have 3 NICs configured for
eth0 - LAN
eth1 - Comcast
eth2 - Uverse
I had no problem getting load balancing set up across the 2 ISPs after reading and it works very well.
What I am struggling with is QOS. I se tup the following QOS rules on the LAN side to tag traffic for dscp based on source address.
This is basic info I have set up for load balancing:
set load-balancing wan enable-local-traffic
set load-balancing wan disable-source-nat
set policy route QOS_RULES
set policy route QOS_RULES description “QOS Rules”
set policy route QOS_RULES rule 100 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 100 set dscp 38
set policy route QOS_RULES rule 131 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 131 set dscp 26
set policy route QOS_RULES rule 132 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 132 set dscp 26
set policy route QOS_RULES rule 133 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 133 set dscp 26
set policy route QOS_RULES rule 134 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 134 set dscp 26
set policy route QOS_RULES rule 135 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 135 set dscp 26
set policy route QOS_RULES rule 136 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 136 set dscp 26
set policy route QOS_RULES rule 161 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 161 set dscp 14
set policy route QOS_RULES rule 162 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 162 set dscp 14
set policy route QOS_RULES rule 171 source address 192.168.y.xxx/32
set policy route QOS_RULES rule 171 set dscp 10
set policy route QOS_RULES rule 199
set policy route QOS_RULES rule 199 source address 192.168.y.xxxx/24
set policy route QOS_RULES rule 199 set dscp 18
set interfaces ethernet eth0 policy route QOS_RULES
I know the rules are working becasue when I do a SHOW POLICY I can see traffic hitting the various rules which means the dscp should be applied. and it show the condition correctly.
I then use the traffic-policy shaper basically following the example from the vyatta manual and several other locations to apply the below:
set traffic-policy shaper Upload-Comcast description “Comcast Upload QOS”
set traffic-policy shaper Upload-Comcast bandwidth 29mbit
set traffic-policy shaper Upload-Comcast default bandwidth 40%
set traffic-policy shaper Upload-Comcast default ceiling 95%
rem set traffic-policy shaper Upload-Comcast default priority 4
set traffic-policy shaper Upload-Comcast class 10 description “Voice”
set traffic-policy shaper Upload-Comcast class 10 bandwidth 10%
set traffic-policy shaper Upload-Comcast class 10 ceiling 95%
set traffic-policy shaper Upload-Comcast class 10 match VOICE ip dscp 38
set traffic-policy shaper Upload-Comcast class 30 description “Video”
set traffic-policy shaper Upload-Comcast class 30 bandwidth 20%
set traffic-policy shaper Upload-Comcast class 30 ceiling 95%
set traffic-policy shaper Upload-Comcast class 30 match VIDEO ip dscp 26
set traffic-policy shaper Upload-Comcast class 60 description “Cloud Backups”
set traffic-policy shaper Upload-Comcast class 60 bandwidth 20%
set traffic-policy shaper Upload-Comcast class 60 ceiling 95%
set traffic-policy shaper Upload-Comcast class 60 match BACKUPS ip dscp 14
set traffic-policy shaper Upload-Comcast class 70 description “Bitorrent”
set traffic-policy shaper Upload-Comcast class 70 bandwidth 10%
set traffic-policy shaper Upload-Comcast class 70 ceiling 75%
set traffic-policy shaper Upload-Comcast class 70 match TORRENTS ip dscp 10
set interfaces ethernet eth1 traffic-policy out Upload-Comcast
The problem is when I use the SHOW QUEUEING ETHERNET command I get the below output which show me that the outbound is all going to default class. Any help would be appreciated as I have been racking my brain for a few days now.
eth0 Queueing:
Class Policy Sent Dropped Overlimit Backlog
root [mq] 1630574341 0 0 0
1 default 707717599 0 0 0
2 default 161641936 0 0 0
3 default 649818700 0 0 0
4 default 111396106 0 0 0
eth1 Queueing:
root shaper 204002131 1030 234407 0
10 fair-queue 0 0 0 0
30 fair-queue 0 0 0 0
60 fair-queue 0 0 0 0
70 fair-queue 0 0 0 0
default fair-queue 204002131 1030 0 0
eth2 Queueing:
root shaper 42596282 183 46425 0
default fair-queue 42596282 183 0 0
As an FYI I had copied some defualt stuff form my EdgeRouter Lite and maybe I don’t need it now:
set interfaces ethernet eth1 description COMCAST
set interfaces ethernet eth2 description UVERSE
set interfaces ethernet eth1 address dhcp
set interfaces ethernet eth2 address dhcp
set nat source rule 5001 outbound-interface eth1
set nat source rule 5001 description ‘NAT masquerade for WAN’
set nat source rule 5001 translation address masquerade
set nat source rule 5002 outbound-interface eth2
set nat source rule 5002 description ‘NAT masquerade for WAN’
set nat source rule 5002 translation address masquerade
Thasks in advance!
