Hello
I am doing lab test in the lab between hardware Cisco ASR 1001-X and virtualized Vyatta on VMware:
Version
vyos@vyos:~$ show version
Version: VyOS 1.3-beta-202105271929
Release Train: equuleus
Built by: [email protected]
Built on: Thu 27 May 2021 17:51 UTC
Build UUID: 23331b23-d00e-46bd-bf08-bbdfda3fbca4
Build Commit ID: aaf3f4b58fbd3b
Architecture: x86_64
Boot via: installed image
System type: VMware guest
Hardware vendor: VMware, Inc.
Hardware S/N: VMware-56 4d e6 b7 42 64 07 53-a4 d2 94 63 1b fb dc 24
Hardware UUID: 564de6b7-4264-0753-a4d2-94631bfbdc24
Vyos configuration
set interfaces ethernet eth0 address ‘192.168.251.1/24’
set interfaces vti vti0 address ‘172.31.250.2/30’
set policy route MSS-CLAMP rule 10 protocol ‘tcp’
set policy route MSS-CLAMP rule 10 set tcp-mss ‘1400’
set policy route MSS-CLAMP rule 10 tcp flags ‘SYN’
set protocols static route 0.0.0.0/0 next-hop 192.168.251.3
set protocols static route 192.168.252.0/31 next-hop 192.168.251.3
set service lldp legacy-protocols cdp
set service ssh
set system host-name ‘vyos’
set system login user vyos authentication encrypted-password ‘$6$cE.w92i.D6OhuNYr$PaFf7iNM6H3YArLy3bRxEezAP0ZgCFAyQ4EnXXZXCt./Iwq0F8l2ap67ZdQ/HpYvhPkjkCLLjzIs/6CWXZwPP.’
set system login user vyos authentication plaintext-password ‘’
set system ntp
set vpn ipsec esp-group ESP_TO_CISCO compression ‘disable’
set vpn ipsec esp-group ESP_TO_CISCO lifetime ‘3600’
set vpn ipsec esp-group ESP_TO_CISCO mode ‘tunnel’
set vpn ipsec esp-group ESP_TO_CISCO pfs ‘dh-group14’
set vpn ipsec esp-group ESP_TO_CISCO proposal 1 encryption ‘aes256gcm128’
set vpn ipsec esp-group ESP_TO_CISCO proposal 1 hash ‘sha256’
set vpn ipsec ike-group IKE_TO_CISCO close-action ‘none’
set vpn ipsec ike-group IKE_TO_CISCO dead-peer-detection action ‘restart’
set vpn ipsec ike-group IKE_TO_CISCO dead-peer-detection interval ‘15’
set vpn ipsec ike-group IKE_TO_CISCO dead-peer-detection timeout ‘30’
set vpn ipsec ike-group IKE_TO_CISCO ikev2-reauth ‘yes’
set vpn ipsec ike-group IKE_TO_CISCO key-exchange ‘ikev2’
set vpn ipsec ike-group IKE_TO_CISCO lifetime ‘28800’
set vpn ipsec ike-group IKE_TO_CISCO proposal 1 dh-group ‘14’
set vpn ipsec ike-group IKE_TO_CISCO proposal 1 encryption ‘aes256gcm128’
set vpn ipsec ike-group IKE_TO_CISCO proposal 1 hash ‘sha256’
set vpn ipsec ipsec-interfaces interface ‘eth0’
set vpn ipsec site-to-site peer 192.168.252.1 authentication id ‘192.168.251.1’
set vpn ipsec site-to-site peer 192.168.252.1 authentication mode ‘pre-shared-secret’
set vpn ipsec site-to-site peer 192.168.252.1 authentication pre-shared-secret ‘vyostocisco’
set vpn ipsec site-to-site peer 192.168.252.1 authentication remote-id ‘192.168.252.1’
set vpn ipsec site-to-site peer 192.168.252.1 connection-type ‘initiate’
set vpn ipsec site-to-site peer 192.168.252.1 default-esp-group ‘ESP_TO_CISCO’
set vpn ipsec site-to-site peer 192.168.252.1 ike-group ‘IKE_TO_CISCO’
set vpn ipsec site-to-site peer 192.168.252.1 ikev2-reauth ‘inherit’
set vpn ipsec site-to-site peer 192.168.252.1 local-address ‘192.168.251.1’
set vpn ipsec site-to-site peer 192.168.252.1 vti bind ‘vti0’
set vpn ipsec site-to-site peer 192.168.252.1 vti esp-group ‘ESP_TO_CISCO’
Outputs:
vyos@vyos:~$ show vpn debug
Status of IKE charon daemon (strongSwan 5.7.2, Linux 5.4.122-amd64-vyos, x86_64):
uptime: 32 minutes, since Jun 10 09:06:39 2021
malloc: sbrk 2015232, mmap 0, used 1351440, free 663792
worker threads: 11 of 16 idle, 5/0/0/0 working, job queue: 0/0/0/0, scheduled: 112
loaded plugins: charon test-vectors ldap pkcs11 tpm aes rc2 sha2 sha1 md5 mgf1 random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl gcrypt af-alg fips-prf gmp curve25519 agent chapoly xcbc cmac hmac ctr ccm gcm curl attr kernel-netlink resolve socket-default connmark stroke vici updown eap-identity eap-aka eap-md5 eap-gtc eap-mschapv2 eap-radius eap-tls eap-ttls eap-tnc xauth-generic xauth-eap xauth-pam tnc-tnccs dhcp lookip error-notify certexpire led addrblock counters
Listening IP addresses:
192.168.251.1
Connections:
peer-192.168.252.1-tunnel-vti: 192.168.251.1…192.168.252.1 IKEv2, dpddelay=15s
peer-192.168.252.1-tunnel-vti: local: [192.168.251.1] uses pre-shared key authentication
peer-192.168.252.1-tunnel-vti: remote: [192.168.252.1] uses pre-shared key authentication
peer-192.168.252.1-tunnel-vti: child: 0.0.0.0/0 === 0.0.0.0/0 TUNNEL, dpdaction=restart
Security Associations (0 up, 0 connecting):
none
vyos@vyos:~$ show vpn ike sa
Peer ID / IP Local ID / IP
192.168.252.1 192.168.251.1
State IKEVer Encrypt Hash D-H Group NAT-T A-Time L-Time
down N/A n/a n/a n/a(n/a) no 0 n/a
vyos@vyos:~$ show vpn ipsec
Possible completions:
policy Show the in-kernel crypto policies
sa Show all active IPsec Security Associations (SA)
state Show the in-kernel crypto state
status Show status of IPsec process
vyos@vyos:~$ show vpn ipsec sa
Connection State Uptime Bytes In/Out Packets In/Out Remote address Remote ID Proposal
vyos@vyos:~$
Cisco ASR 1001-X
Cisco Configuration
cisco#sh run | sec crypto
crypto ikev2 proposal vyos-ikev2-proposal
encryption aes-gcm-256
prf sha256
group 14
crypto ikev2 policy vyos-ikev2-policy
match address local 192.168.252.1
crypto ikev2 profile vyos-ikev2-profile
match identity remote address 192.168.251.1 255.255.255.255
authentication remote pre-share key vyostocisco
authentication local pre-share key vyostocisco
dpd 30 15 periodic
crypto ipsec transform-set vyos_transform esp-gcm 256
mode tunnel
crypto ipsec profile vyos_ipsec
set transform-set vyos_transform
set ikev2-profile vyos-ikev2-profile
nterface GigabitEthernet0/0/1.252
encapsulation dot1Q 252
ip address 192.168.252.1 255.255.255.254
ip route 192.168.251.0 255.255.255.0 192.168.252.0
interface Tunnel1000
description VPN Tunnel to VyOS
ip address 172.31.250.1 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1360
tunnel source 192.168.252.1
tunnel mode ipsec ipv4
tunnel destination 192.168.251.1
tunnel protection ipsec profile vyos_ipsec
end
Cisco outputs
cisco#show crypto ikev2 sa
cisco#show crypto ikev2 stats
Crypto IKEv2 SA Statistics
System Resource Limit: 0 Max IKEv2 SAs: 0 Max in nego(in/out): 40/400
Total incoming IKEv2 SA Count: 0 active: 0 negotiating: 0
Total outgoing IKEv2 SA Count: 0 active: 0 negotiating: 0
Incoming IKEv2 Requests: 5 accepted: 5 rejected: 0
Outgoing IKEv2 Requests: 136 accepted: 136 rejected: 0
Rejected IKEv2 Requests: 0 rsrc low: 0 SA limit: 0
IKEv2 packets dropped at dispatch: 0
Incoming IKEV2 Cookie Challenged Requests: 0
accepted: 0 rejected: 0 rejected no cookie: 0
Total Deleted sessions of Cert Revoked Peers: 0
cisco#show crypto ipsec sa
interface: Tunnel1000
Crypto map tag: Tunnel1000-head-0, local addr 192.168.252.1
protected vrf: (none)
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer 192.168.251.1 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 192.168.252.1, remote crypto endpt.: 192.168.251.1
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1.252
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
I would like to note that similar configuration is working fine between Cisco CSR1000V and vyos same version within Eve-NG virtualized lab
