I’m having an issue BGP peering a physical Mikrotik router on the same LAN as a virtual Vyos (rolling) instance.
On the Vyos side I used the following commands:
set protocols bgp 65010 address-family ipv4-unicast redistribute connected
set protocols bgp 65010 neighbor 10.13.2.10 remote-as ‘65020’
set protocols bgp 65010 neighbor 10.13.2.10 capability dynamic
set protocols bgp 65010 parameters router-id 172.26.13.101
And I now see this:
show ip bgp summary
IPv4 Unicast Summary:
BGP router identifier 172.26.13.101, local AS number 65010 vrf-id 0
BGP table version 5
RIB entries 5, using 960 bytes of memory
Peers 1, using 21 KiB of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd PfxSnt
10.13.2.10 4 65020 0 0 0 0 0 never Active 0
Ok the Mikrotik side I setup a BGP peer (RouterOS):
/routing bgp instance
set default as=65020
/routing bgp peer
add name=Vyos01 remote-address=172.26.13.101 remote-as=65010
From each router appliance I can ping the peer IP address. However, the two routers won’t peer. Ideas?
