Hi, attempting to build 1.2 ISO using docker inside of a Buster machine. All prereqs are installed, and I’m getting the infamous “Extra argument error” when installing the kernel.
invoke-rc.d: policy-rc.d denied execution of restart.
Processing triggers for systemd (215-17+deb8u13) ...
I: Create initramfs if it does not exist.
/root/17-gen_initramfs.chroot: line 8: [: /boot/initrd.img-4.19.190-amd64-vyos: binary operator expected
Extra argument '4.19.194-amd64-vyos'
Usage: /usr/sbin/update-initramfs.orig.initramfs-tools [OPTION]...
Options:
-k version Specify kernel version or 'all'
-c Create a new initramfs
-u Update an existing initramfs
-d Remove an existing initramfs
-t Take over a custom initramfs with this one
-b directory Set alternate boot directory
-v Be verbose
-h This message
E: config/hooks/live/17-gen_initramfs.chroot failed (exit non-zero). You should check for errors.
I’m not trying to do any custom kernel, just a basic factory ISO. I have attempted to build the kernel myself, but then QAT fails. Any further guidance on this?
