Hi there,
Ocationally found that can’t make inplace upgrade by any version after 1.5-rolling-202409160007
Issue isn’t clear.
Even very simple configuration normally booted on 1.5-rolling-202409160007 gives configuration migration error on latter night builds
set interfaces ethernet eth0 address 'xxx.xxx.0.12/24'
set interfaces ethernet eth0 description 'Local network Interface'
set interfaces ethernet eth0 hw-id 'xx:xx:xx:xx:xx:7b'
set interfaces ethernet eth0 ip enable-arp-announce
set interfaces ethernet eth0 ip enable-proxy-arp
set interfaces ethernet eth3 hw-id 'xx:xx:xx:xx:xx:e6'
set interfaces ethernet eth3 offload gro
set interfaces ethernet eth3 offload gso
set interfaces ethernet eth3 offload sg
set interfaces ethernet eth3 offload tso
set interfaces loopback lo
set service dns forwarding allow-from 'xxx.xxx.0.0/24'
set service dns forwarding cache-size '150'
set service dns forwarding listen-address 'xxx.xxx.0.12'
set service dns forwarding name-server xxx.xxx.184.3
set service dns forwarding name-server xxx.xxx.74.3
set service dns forwarding system
set service ntp allow-client xxxxxx 'xxx.xxx.0.0/0'
set service ntp allow-client xxxxxx '::/0'
set service ssh disable-host-validation
set service ssh disable-password-authentication
set service ssh port '12322'
set system host-name xxxxxx
set system login banner post-login 'VyOS 1.5-rolling-202407060019'
set system login user xxxxxx authentication public-keys [email protected] key xxxxxx
set system login user xxxxxx authentication public-keys [email protected] type ssh-xxx
set system login user xxxxxx authentication public-keys [email protected] type 'ecdsa-sha2-nistp521'
set system name-server 'xxx.xxx.184.3'
set system name-server 'xxx.xxx.74.3'
Configure | load | commit sequence gives lot of IndexOfRange errors somewhere in ethernet section.
Unfortunately there is no ability to copy output due to limitation of virtual console.
What log I should check to see the root of issue?
Thanks
