Can't see default parameters using 'show configuration all'
Hello all,
looks like ‘show configuration all’ shows same config as ‘show configuration’. I’m using rolling release:
vyos@vyos:~$ show version
Version:          VyOS 1.5-rolling-202310211449
Release train:    current
Built on:         Sat 21 Oct 2023 16:10 UTC
Build UUID:       9c81a02e-b284-4152-a7ad-a0118690194e
Build commit ID:  142e8770563716
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  QEMU
Hardware model:   Standard PC (i440FX + PIIX, 1996)
Hardware S/N:
Hardware UUID:    7f83e94a-a367-4c8a-aa75-41f1aae24a16
vyos@vyos:~$
Does anyone see same behavior?
Thanks in advance, regards,
Konstantin
Seems to be the case with a few days older 1.5-rolling aswell:
Version:          VyOS 1.5-rolling-202310170806
Built on:         Tue 17 Oct 2023 09:32 UTC
Build UUID:       a79a3799-cdad-4791-9fe5-63f6eff7d535
Build commit ID:  ad214dba3ec08a
Hardware vendor:  innotek GmbH
Hardware model:   VirtualBox
Hardware S/N:     0
Hardware UUID:    6f68ed51-cca1-3945-8185-39eae1e20b8d
Please file this as a bugreport over at https://vyos.dev or let me know if you want me to do it (its preferred if the original reporter can file it to better verify if/when the issue is actually resolved).
Thanks for your prompt answer, seems this problem is quite old, same issue on 1.4-rolling-202308220020.
I’ll file the report as soon as my registration approved.
Regards,
Konstantin
https://vyos.dev/T5675
