Change keyboard and language settings
Hello!
How can I change the keyboard and language settings to customize my Vyos 1.1.1 installation for my preferred country?
THX
Hello c.monty.
Maybe you can change keyboard type with the following commands.
Please execute this command before install image.
sudo dpkg-reconfigure console-data
And choise Select keymap from full list.
Hiroyuki Sato.
This is not working.
I can configure keymap “de-latin1-nodeadkeys”, but after rebooting the machine the old keymap is activated again.
Is there any option to modify this?
THX
Hello c.monty.
Please try
set console keymap
This is operation mode command. you don’t need configure.
I didn’t know this command.
Hiroyuki Sato
