CLI claims it does not find cert files in auth directory but they definitely exist, the commit works and so does the SSTP VPN:
Hello @kav, which version. I don’t see a similar output on the latest rolling.
Your screenshot has a bad quality, can you provide output of command ls -la /config/auth/ as a text?
hey @Dmitry,
Ah yes… that would seem to answer it, they were actually links to the actual files, which were in the /etc/letsencrypt/live/ folder.
I’ll leave them as links and ignore the error
