New user here. Cannot upload attachments. Posting the /var/log/cloud-init.log content here:
2021-03-20 22:10:48,823 - util.py[DEBUG]: Cloud-init v. 20.4-396-g3b0c82a4-1~bddeb running 'init-local' at Sat, 20 Mar 2021 22:10:48 +0000. Up 5.52 seconds.
2021-03-20 22:10:48,823 - main.py[DEBUG]: No kernel command line url found.
2021-03-20 22:10:48,823 - main.py[DEBUG]: Closing stdin.
2021-03-20 22:10:48,825 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2021-03-20 22:10:48,826 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 0:4
2021-03-20 22:10:48,826 - util.py[DEBUG]: Attempting to remove /opt/vyatta/etc/config/cloud/instance/boot-finished
2021-03-20 22:10:48,826 - util.py[DEBUG]: Attempting to remove /opt/vyatta/etc/config/cloud/data/no-net
2021-03-20 22:10:48,826 - handlers.py[DEBUG]: start: init-local/check-cache: attempting to read from cache [check]
2021-03-20 22:10:48,826 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/instance/obj.pkl (quiet=False)
2021-03-20 22:10:48,826 - stages.py[DEBUG]: no cache found
2021-03-20 22:10:48,826 - handlers.py[DEBUG]: finish: init-local/check-cache: SUCCESS: no cache found
2021-03-20 22:10:48,830 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.debian.Distro'>
2021-03-20 22:10:48,830 - __init__.py[DEBUG]: Looking for data source in: ['NoCloud', 'None'], via packages ['', 'cloudinit.sources'] that matches dependencies ['FILESYSTEM']
2021-03-20 22:10:48,839 - __init__.py[DEBUG]: Searching for local data source in: ['DataSourceNoCloud']
2021-03-20 22:10:48,839 - handlers.py[DEBUG]: start: init-local/search-NoCloud: searching for local data from DataSourceNoCloud
2021-03-20 22:10:48,839 - __init__.py[DEBUG]: Seeing if we can get any data from <class 'cloudinit.sources.DataSourceNoCloud.DataSourceNoCloud'>
2021-03-20 22:10:48,839 - __init__.py[DEBUG]: Update datasource metadata and network config due to events: New instance first boot
2021-03-20 22:10:48,839 - dmi.py[DEBUG]: querying dmi data /sys/class/dmi/id/product_serial
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud/user-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud/meta-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud/vendor-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud/network-config (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud-net/user-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud-net/meta-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud-net/vendor-data (quiet=False)
2021-03-20 22:10:48,842 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/seed/nocloud-net/network-config (quiet=False)
2021-03-20 22:10:48,842 - subp.py[DEBUG]: Running command ['blkid', '-tTYPE=vfat', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-20 22:10:48,867 - subp.py[DEBUG]: Running command ['blkid', '-tTYPE=iso9660', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-20 22:10:48,879 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL=CIDATA', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-20 22:10:48,896 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL=cidata', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-20 22:10:48,916 - subp.py[DEBUG]: Running command ['blkid', '-tLABEL_FATBOOT=cidata', '-odevice'] with allowed return codes [0, 2] (shell=False, capture=True)
2021-03-20 22:10:48,930 - DataSourceNoCloud.py[DEBUG]: Attempting to use data from /dev/sr1
2021-03-20 22:10:48,930 - util.py[DEBUG]: Reading from /proc/mounts (quiet=False)
2021-03-20 22:10:48,930 - util.py[DEBUG]: Read 2326 bytes from /proc/mounts
2021-03-20 22:10:48,930 - util.py[DEBUG]: Fetched {'sysfs': {'fstype': 'sysfs', 'mountpoint': '/sys', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'proc': {'fstype': 'proc', 'mountpoint': '/proc', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'udev': {'fstype': 'devtmpfs', 'mountpoint': '/dev', 'opts': 'rw,nosuid,relatime,size=468760k,nr_inodes=117190,mode=755'}, 'devpts': {'fstype': 'devpts', 'mountpoint': '/dev/pts', 'opts': 'rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000'}, 'tmpfs': {'fstype': 'tmpfs', 'mountpoint': '/tmp', 'opts': 'rw,nosuid,nodev,relatime'}, '/dev/sr0': {'fstype': 'iso9660', 'mountpoint': '/usr/lib/live/mount/medium', 'opts': 'ro,noatime,nojoliet,check=s,map=n,blocksize=2048'}, '/dev/loop0': {'fstype': 'squashfs', 'mountpoint': '/usr/lib/live/mount/rootfs/filesystem.squashfs', 'opts': 'ro,noatime'}, 'overlay': {'fstype': 'overlay', 'mountpoint': '/', 'opts': 'rw,noatime,lowerdir=//filesystem.squashfs/,upperdir=/live/overlay//rw,workdir=/live/overlay//work'}, 'securityfs': {'fstype': 'securityfs', 'mountpoint': '/sys/kernel/security', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'cgroup2': {'fstype': 'cgroup2', 'mountpoint': '/sys/fs/cgroup/unified', 'opts': 'rw,nosuid,nodev,noexec,relatime,nsdelegate'}, 'cgroup': {'fstype': 'cgroup', 'mountpoint': '/sys/fs/cgroup/pids', 'opts': 'rw,nosuid,nodev,noexec,relatime,pids'}, 'pstore': {'fstype': 'pstore', 'mountpoint': '/sys/fs/pstore', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'efivarfs': {'fstype': 'efivarfs', 'mountpoint': '/sys/firmware/efi/efivars', 'opts': 'rw,nosuid,nodev,noexec,relatime'}, 'none': {'fstype': 'bpf', 'mountpoint': '/sys/fs/bpf', 'opts': 'rw,nosuid,nodev,noexec,relatime,mode=700'}, 'systemd-1': {'fstype': 'autofs', 'mountpoint': '/proc/sys/fs/binfmt_misc', 'opts': 'rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct'}, 'debugfs': {'fstype': 'debugfs', 'mountpoint': '/sys/kernel/debug', 'opts': 'rw,relatime'}, 'mqueue': {'fstype': 'mqueue', 'mountpoint': '/dev/mqueue', 'opts': 'rw,relatime'}} mounts from proc
2021-03-20 22:10:48,931 - subp.py[DEBUG]: Running command ['mount', '-o', 'ro', '-t', 'auto', '/dev/sr1', '/run/cloud-init/tmp/tmp0muw8yt7'] with allowed return codes [0] (shell=False, capture=True)
2021-03-20 22:10:48,951 - util.py[DEBUG]: Reading from /run/cloud-init/tmp/tmp0muw8yt7//user-data (quiet=False)
2021-03-20 22:10:48,951 - util.py[DEBUG]: Read 379 bytes from /run/cloud-init/tmp/tmp0muw8yt7//user-data
2021-03-20 22:10:48,951 - util.py[DEBUG]: Reading from /run/cloud-init/tmp/tmp0muw8yt7//meta-data (quiet=False)
2021-03-20 22:10:48,952 - util.py[DEBUG]: Read 72 bytes from /run/cloud-init/tmp/tmp0muw8yt7//meta-data
2021-03-20 22:10:48,952 - util.py[DEBUG]: Reading from /run/cloud-init/tmp/tmp0muw8yt7//vendor-data (quiet=False)
2021-03-20 22:10:48,952 - util.py[DEBUG]: Reading from /run/cloud-init/tmp/tmp0muw8yt7//network-config (quiet=False)
2021-03-20 22:10:48,952 - util.py[DEBUG]: Read 50 bytes from /run/cloud-init/tmp/tmp0muw8yt7//network-config
2021-03-20 22:10:48,952 - subp.py[DEBUG]: Running command ['umount', '/run/cloud-init/tmp/tmp0muw8yt7'] with allowed return codes [0] (shell=False, capture=True)
2021-03-20 22:10:48,955 - util.py[DEBUG]: Attempting to load yaml from string of length 72 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,956 - util.py[DEBUG]: Attempting to load yaml from string of length 50 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,956 - DataSourceNoCloud.py[DEBUG]: Using data from /dev/sr1
2021-03-20 22:10:48,957 - atomic_helper.py[DEBUG]: Atomically writing to file /run/cloud-init/instance-data-sensitive.json (via temporary file /run/cloud-init/tmpzcf29z95) - w: [600] 4308 bytes/chars
2021-03-20 22:10:48,957 - atomic_helper.py[DEBUG]: Atomically writing to file /run/cloud-init/instance-data.json (via temporary file /run/cloud-init/tmp9ho3i2yw) - w: [644] 1504 bytes/chars
2021-03-20 22:10:48,957 - handlers.py[DEBUG]: finish: init-local/search-NoCloud: SUCCESS: found local data from DataSourceNoCloud
2021-03-20 22:10:48,958 - stages.py[INFO]: Loaded datasource DataSourceNoCloud - DataSourceNoCloud [seed=/dev/sr1][dsmode=net]
2021-03-20 22:10:48,958 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-20 22:10:48,958 - util.py[DEBUG]: Read 3581 bytes from /etc/cloud/cloud.cfg
2021-03-20 22:10:48,958 - util.py[DEBUG]: Attempting to load yaml from string of length 3581 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,964 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-20 22:10:48,965 - util.py[DEBUG]: Read 248 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-20 22:10:48,965 - util.py[DEBUG]: Attempting to load yaml from string of length 248 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,967 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/10_vyos.cfg (quiet=False)
2021-03-20 22:10:48,967 - util.py[DEBUG]: Read 1360 bytes from /etc/cloud/cloud.cfg.d/10_vyos.cfg
2021-03-20 22:10:48,967 - util.py[DEBUG]: Attempting to load yaml from string of length 1360 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,971 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-20 22:10:48,971 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-20 22:10:48,971 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,973 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-20 22:10:48,973 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-20 22:10:48,973 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,973 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,973 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-20 22:10:48,974 - util.py[DEBUG]: Attempting to remove /opt/vyatta/etc/config/cloud/instance
2021-03-20 22:10:48,974 - util.py[DEBUG]: Creating symbolic link from '/opt/vyatta/etc/config/cloud/instance' => '/opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd'
2021-03-20 22:10:48,974 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/datasource (quiet=False)
2021-03-20 22:10:48,974 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/datasource - wb: [644] 65 bytes
2021-03-20 22:10:48,974 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/previous-datasource - wb: [644] 65 bytes
2021-03-20 22:10:48,974 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/data/instance-id (quiet=False)
2021-03-20 22:10:48,974 - stages.py[DEBUG]: previous iid found to be NO_PREVIOUS_INSTANCE_ID
2021-03-20 22:10:48,975 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/instance-id - wb: [644] 37 bytes
2021-03-20 22:10:48,975 - util.py[DEBUG]: Writing to /run/cloud-init/.instance-id - wb: [644] 37 bytes
2021-03-20 22:10:48,975 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/previous-instance-id - wb: [644] 24 bytes
2021-03-20 22:10:48,975 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instance/obj.pkl - wb: [400] 6218 bytes
2021-03-20 22:10:48,975 - main.py[DEBUG]: [local] init will now be targeting instance id: 943688a4-5218-4997-bf64-bb0554f09cfd. new=True
2021-03-20 22:10:48,975 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-20 22:10:48,975 - util.py[DEBUG]: Read 3581 bytes from /etc/cloud/cloud.cfg
2021-03-20 22:10:48,975 - util.py[DEBUG]: Attempting to load yaml from string of length 3581 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,984 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-20 22:10:48,984 - util.py[DEBUG]: Read 248 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-20 22:10:48,984 - util.py[DEBUG]: Attempting to load yaml from string of length 248 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,986 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/10_vyos.cfg (quiet=False)
2021-03-20 22:10:48,986 - util.py[DEBUG]: Read 1360 bytes from /etc/cloud/cloud.cfg.d/10_vyos.cfg
2021-03-20 22:10:48,986 - util.py[DEBUG]: Attempting to load yaml from string of length 1360 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,988 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-20 22:10:48,989 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-20 22:10:48,989 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,992 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-20 22:10:48,992 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-20 22:10:48,992 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,992 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:48,992 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-20 22:10:48,993 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.debian.Distro'>
2021-03-20 22:10:48,994 - cc_set_hostname.py[DEBUG]: Configuration option 'preserve_hostname' is set, not setting the hostname in module set-hostname
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth0/address (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth0/address
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth1/address (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth1/address
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth0/addr_assign_type (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eth0/addr_assign_type
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth0/uevent (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eth0/uevent
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth0/device/device (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 4 bytes from /sys/class/net/eth0/device/device
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth1/addr_assign_type (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eth1/addr_assign_type
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth1/uevent (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eth1/uevent
2021-03-20 22:10:48,995 - util.py[DEBUG]: Reading from /sys/class/net/eth1/device/device (quiet=False)
2021-03-20 22:10:48,995 - util.py[DEBUG]: Read 4 bytes from /sys/class/net/eth1/device/device
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/lo/addr_assign_type (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/lo/addr_assign_type
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/lo/uevent (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 23 bytes from /sys/class/net/lo/uevent
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/lo/device/device (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/eth0/type (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eth0/type
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/eth1/type (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eth1/type
2021-03-20 22:10:48,996 - util.py[DEBUG]: Reading from /sys/class/net/lo/type (quiet=False)
2021-03-20 22:10:48,996 - util.py[DEBUG]: Read 4 bytes from /sys/class/net/lo/type
2021-03-20 22:10:48,996 - networking.py[DEBUG]: net: all expected physical devices present
2021-03-20 22:10:48,996 - stages.py[DEBUG]: applying net config names for {'version': 2, 'ethernets': {'eth0': {'dhcp4': True}}}
2021-03-20 22:10:48,996 - __init__.py[DEBUG]: no interfaces to rename
2021-03-20 22:10:48,996 - stages.py[INFO]: Applying network configuration from ds bringup=False: {'version': 2, 'ethernets': {'eth0': {'dhcp4': True}}}
2021-03-20 22:10:48,998 - stages.py[ERROR]: Unable to render networking. Network config is likely broken: No available network renderers found. Searched through list: ['netplan', 'eni', 'sysconfig']
2021-03-20 22:10:49,001 - main.py[DEBUG]: [local] Exiting. datasource DataSourceNoCloud [seed=/dev/sr1][dsmode=net] not in local mode.
2021-03-20 22:10:49,001 - atomic_helper.py[DEBUG]: Atomically writing to file /var/lib/cloud/data/status.json (via temporary file /var/lib/cloud/data/tmplbmeady4) - w: [644] 518 bytes/chars
2021-03-20 22:10:49,001 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2021-03-20 22:10:49,001 - util.py[DEBUG]: Read 10 bytes from /proc/uptime
2021-03-20 22:10:49,001 - util.py[DEBUG]: cloud-init mode 'init' took 0.225 seconds (0.23)
2021-03-20 22:10:49,001 - handlers.py[DEBUG]: finish: init-local: SUCCESS: searching for local datasources
2021-03-20 22:10:49,423 - util.py[DEBUG]: Cloud-init v. 20.4-396-g3b0c82a4-1~bddeb running 'init' at Sat, 20 Mar 2021 22:10:49 +0000. Up 6.12 seconds.
2021-03-20 22:10:49,423 - main.py[DEBUG]: No kernel command line url found.
2021-03-20 22:10:49,423 - main.py[DEBUG]: Closing stdin.
2021-03-20 22:10:49,424 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2021-03-20 22:10:49,424 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 0:4
2021-03-20 22:10:49,424 - subp.py[DEBUG]: Running command ['ip', 'addr', 'show'] with allowed return codes [0] (shell=False, capture=True)
2021-03-20 22:10:49,429 - subp.py[DEBUG]: Running command ['ip', '-o', 'route', 'list'] with allowed return codes [0] (shell=False, capture=True)
2021-03-20 22:10:49,430 - subp.py[DEBUG]: Running command ['ip', '--oneline', '-6', 'route', 'list', 'table', 'all'] with allowed return codes [0, 1] (shell=False, capture=True)
2021-03-20 22:10:49,438 - main.py[DEBUG]: Checking to see if files that we need already exist from a previous run that would allow us to stop early.
2021-03-20 22:10:49,438 - main.py[DEBUG]: Execution continuing, no previous run detected that would allow us to stop early.
2021-03-20 22:10:49,438 - handlers.py[DEBUG]: start: init-network/check-cache: attempting to read from cache [trust]
2021-03-20 22:10:49,438 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/instance/obj.pkl (quiet=False)
2021-03-20 22:10:49,438 - util.py[DEBUG]: Read 6218 bytes from /opt/vyatta/etc/config/cloud/instance/obj.pkl
2021-03-20 22:10:49,439 - util.py[DEBUG]: Reading from /run/cloud-init/.instance-id (quiet=False)
2021-03-20 22:10:49,439 - util.py[DEBUG]: Read 37 bytes from /run/cloud-init/.instance-id
2021-03-20 22:10:49,439 - stages.py[DEBUG]: restored from cache with run check: DataSourceNoCloud [seed=/dev/sr1][dsmode=net]
2021-03-20 22:10:49,439 - handlers.py[DEBUG]: finish: init-network/check-cache: SUCCESS: restored from cache with run check: DataSourceNoCloud [seed=/dev/sr1][dsmode=net]
2021-03-20 22:10:49,440 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-20 22:10:49,440 - util.py[DEBUG]: Read 3581 bytes from /etc/cloud/cloud.cfg
2021-03-20 22:10:49,440 - util.py[DEBUG]: Attempting to load yaml from string of length 3581 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,450 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-20 22:10:49,450 - util.py[DEBUG]: Read 248 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-20 22:10:49,450 - util.py[DEBUG]: Attempting to load yaml from string of length 248 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,451 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/10_vyos.cfg (quiet=False)
2021-03-20 22:10:49,451 - util.py[DEBUG]: Read 1360 bytes from /etc/cloud/cloud.cfg.d/10_vyos.cfg
2021-03-20 22:10:49,451 - util.py[DEBUG]: Attempting to load yaml from string of length 1360 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,454 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-20 22:10:49,454 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-20 22:10:49,454 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,456 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-20 22:10:49,456 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-20 22:10:49,456 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,456 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,456 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-20 22:10:49,459 - util.py[DEBUG]: Attempting to remove /opt/vyatta/etc/config/cloud/instance
2021-03-20 22:10:49,459 - util.py[DEBUG]: Creating symbolic link from '/opt/vyatta/etc/config/cloud/instance' => '/opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd'
2021-03-20 22:10:49,460 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/datasource (quiet=False)
2021-03-20 22:10:49,460 - util.py[DEBUG]: Read 65 bytes from /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/datasource
2021-03-20 22:10:49,460 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/datasource - wb: [644] 65 bytes
2021-03-20 22:10:49,460 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/previous-datasource - wb: [644] 65 bytes
2021-03-20 22:10:49,460 - util.py[DEBUG]: Reading from /opt/vyatta/etc/config/cloud/data/instance-id (quiet=False)
2021-03-20 22:10:49,460 - util.py[DEBUG]: Read 37 bytes from /opt/vyatta/etc/config/cloud/data/instance-id
2021-03-20 22:10:49,460 - stages.py[DEBUG]: previous iid found to be 943688a4-5218-4997-bf64-bb0554f09cfd
2021-03-20 22:10:49,460 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/instance-id - wb: [644] 37 bytes
2021-03-20 22:10:49,460 - util.py[DEBUG]: Writing to /run/cloud-init/.instance-id - wb: [644] 37 bytes
2021-03-20 22:10:49,461 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/data/previous-instance-id - wb: [644] 37 bytes
2021-03-20 22:10:49,462 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instance/obj.pkl - wb: [400] 6308 bytes
2021-03-20 22:10:49,462 - main.py[DEBUG]: [net] init will now be targeting instance id: 943688a4-5218-4997-bf64-bb0554f09cfd. new=False
2021-03-20 22:10:49,462 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2021-03-20 22:10:49,462 - util.py[DEBUG]: Read 3581 bytes from /etc/cloud/cloud.cfg
2021-03-20 22:10:49,462 - util.py[DEBUG]: Attempting to load yaml from string of length 3581 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,472 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2021-03-20 22:10:49,472 - util.py[DEBUG]: Read 248 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2021-03-20 22:10:49,472 - util.py[DEBUG]: Attempting to load yaml from string of length 248 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,473 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/10_vyos.cfg (quiet=False)
2021-03-20 22:10:49,473 - util.py[DEBUG]: Read 1360 bytes from /etc/cloud/cloud.cfg.d/10_vyos.cfg
2021-03-20 22:10:49,473 - util.py[DEBUG]: Attempting to load yaml from string of length 1360 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,476 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2021-03-20 22:10:49,476 - util.py[DEBUG]: Read 2070 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2021-03-20 22:10:49,476 - util.py[DEBUG]: Attempting to load yaml from string of length 2070 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,479 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2021-03-20 22:10:49,479 - util.py[DEBUG]: Read 35 bytes from /run/cloud-init/cloud.cfg
2021-03-20 22:10:49,479 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,479 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,479 - util.py[DEBUG]: loaded blob returned None, returning default.
2021-03-20 22:10:49,480 - util.py[DEBUG]: Reading from /sys/class/net/eth0/address (quiet=False)
2021-03-20 22:10:49,480 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth0/address
2021-03-20 22:10:49,480 - util.py[DEBUG]: Reading from /sys/class/net/eth1/address (quiet=False)
2021-03-20 22:10:49,480 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eth1/address
2021-03-20 22:10:49,480 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2021-03-20 22:10:49,480 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2021-03-20 22:10:49,480 - __init__.py[DEBUG]: Datasource DataSourceNoCloud [seed=/dev/sr1][dsmode=net] not updated for events: System boot
2021-03-20 22:10:49,480 - stages.py[DEBUG]: No network config applied. Neither a new instance nor datasource network update on 'System boot' event
2021-03-20 22:10:49,480 - stages.py[DEBUG]: applying net config names for {'version': 2, 'ethernets': {'eth0': {'dhcp4': True}}}
2021-03-20 22:10:49,480 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.debian.Distro'>
2021-03-20 22:10:49,481 - __init__.py[DEBUG]: no interfaces to rename
2021-03-20 22:10:49,481 - handlers.py[DEBUG]: start: init-network/setup-datasource: setting up datasource
2021-03-20 22:10:49,481 - handlers.py[DEBUG]: finish: init-network/setup-datasource: SUCCESS: setting up datasource
2021-03-20 22:10:49,481 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/user-data.txt - wb: [600] 379 bytes
2021-03-20 22:10:49,482 - util.py[DEBUG]: Attempting to load yaml from string of length 379 with allowed root types (<class 'dict'>,)
2021-03-20 22:10:49,488 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/user-data.txt.i - wb: [600] 661 bytes
2021-03-20 22:10:49,489 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/vendor-data.txt - wb: [600] 0 bytes
2021-03-20 22:10:49,491 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/vendor-data.txt.i - wb: [600] 308 bytes
2021-03-20 22:10:49,492 - cc_set_hostname.py[DEBUG]: Configuration option 'preserve_hostname' is set, not setting the hostname in module set-hostname
2021-03-20 22:10:49,492 - util.py[DEBUG]: Writing to /opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/sem/consume_data - wb: [644] 24 bytes
2021-03-20 22:10:49,492 - helpers.py[DEBUG]: Running consume_data using lock (<FileLock using file '/opt/vyatta/etc/config/cloud/instances/943688a4-5218-4997-bf64-bb0554f09cfd/sem/consume_data'>)
2021-03-20 22:10:49,492 - handlers.py[DEBUG]: start: init-network/consume-user-data: reading and applying user-data
2021-03-20 22:10:49,492 - stages.py[DEBUG]: Added default handler for {'text/cloud-config', 'text/cloud-config-jsonp'} from CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']]
