I have been experiencing random blocks from Cloudflare when building a 1.4 image. Is this now geographically limited and if so, what should I be using from the US?
Failed to fetch http://dev.packages.vyos.net/repositories/sagitta/dists/sagitta/InRelease 403 Forbidden [IP: 104.18.31.79 443]
This is doing a build from a Docker container.
This has been discussed ad nauseam on the forum. Please see the initial blog post and then one of the follow-up threads.
TL;DR As of now, you can only build rolling releases (1.5) using the standard build procedure. Anything else is not officially supported for building and you’ll need to setup your own full build environment (Jenkins etc…) for that.
Your personal rolling .iso is not supported either. Wrong information.
It is not true. You can build them.
Thanks for the correction. Very impressive that you guys would support a customer’s build.
Can we please modify the documentation to reflect this? If you read the docs today, it looks like you can still build 1.2, 1.3, and 1.4. But you need to walk all the way through the process and fail, and then search here to find out why. That’s not so cool.
