I have question about clustering. Can Vyos run cluster in active-active mode with asymmetric routing and NAT? I know that i can run conntrack-sync but i didn’t find any information how to make it work in both ways between two active routers.
Hello, @mansonik!
Could you describe the topology? Do you mean the situation when traffic passes one of the routers in one direction and another router in reverse direction, and both this routers is in the cluster?
It will be better if you will draw a scheme with this topology.
