When trying to use the set system config-management commit-archive location commands, the errors was (60) SSL peer certificate or SSH remote key was not OK
So after digging and not automatically generating a key, I modified the /opt/vyatta/sbin/vyatta-commit-push.pl file and placed -k in the following section
$cmd = “curl -g -s -S -T $tmp_push_file $uri/$save_file”;
$cmd = “curl -k -g -s -S -T $tmp_push_file $uri/$save_file”;
Once I had done this I was getting a new error
curl: (79) Upload failed: Operation failed (4/-31)
I then discovered I needed to add /~/ for it to work.
set system config-management commit-archive location scp://user:password@IPaddress/~/Downloads/
Hope it helps others who struggled like me!
tjh
April 26, 2020, 9:46pm
3
Thanks @badger72 - Can you confirm what version of Vyos this was with?
The version is VyOS 1.3-rolling-202004230117
I can confirm that this behavior still there in VyOS 1.4-rolling-202103210217
, adding -k in curl command in vyatta-commit-push.pl
didn’t fix the curl 60 error
Use this command to generate the ssh fingerprint of your host.
ssh-keyscan >> ~/.ssh/known_hosts
Then you can configure the commit-archive command for scp or others.
Reference link:
https://docs.vyos.io/en/latest/cli.html#remote-archive
Tested in the lab:
vyos@vyos:~$ sh ver
Version: VyOS 1.4-rolling-202103251004
Release Train: sagitta
Built by: autobuild@vyos.net
Built on: Thu 25 Mar 2021 10:09 UTC
vyos@vyos:~$ sudo ssh-keyscan 192.168.x.x >> ~/.ssh/known_hosts
# 192.168.x.x:22 SSH-2.0-OpenSSH_7.9p1 Debian-10+deb10u2
[edit system config-management]
vyos@vyos# set commit-archive location scp://root:root@192.168.x.x/root/backup
vyos@vyos# commit
Archiving config...
scp://192.168.x.x/root/backup OK
root@debian:~# ls -ltr /root/backup
total 12
-rw-r--r-- 1 root root 1205 Mar 29 01:52 config.boot-vyos.20210329_095215
-rw-r--r-- 1 root root 1205 Mar 29 02:04 config.boot-vyos.20210329_100404
-rw-r--r-- 1 root root 1204 Mar 29 02:04 config.boot-lab.20210329_100448
This works as expected.
