can you help me, I’m having problems adding a vlan or changing the configuration on one of the interfaces, I’m using a HPE Ethernet 10Gb 2-port 530SFP+ Adapter on a Dell Poweredge R630, the following is the attached log while committing.
najib@vyos:~$ configure
najib@vyos# set interfaces ethernet eth5 vif 1000
najib@vyos# commit
could not set flowcontrol for eth5
[ interfaces ethernet eth5 ]
- Make sure you are running the latest version of the code available at
https://downloads.vyos.io/rolling/current/amd64/vyos-rolling-latest.iso
- Consult the forum to see how to handle this issue
https://forum.vyos.io
- Join our community on slack where our users exchange help and advice
https://vyos.slack.com
business policy requires it)
Report Time: 2021-06-30 14:39:16
Image Version: VyOS 1.4-rolling-202106290839
Release Train: sagitta
Built by: [email protected]
Built on: Tue 29 Jun 2021 16:38 UTC
Build UUID: 818f899d-4004-4c1b-a98d-f1b687013088
Build Commit ID: ce49275606e303
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Dell Inc.
Hardware model: PowerEdge R630
Hardware S/N: HW2DH32
Hardware UUID: 4c4c4544-0057-3210-8044-c8c04f483332
File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 157, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 146, in apply
e.update(ethernet)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 367, in update
self.set_speed_duplex(speed, duplex)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 219, in set_speed_duplex
return self._cmd(cmd)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 51, in _cmd
return cmd(command, self.debug)
File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
raise OSError(code, feedback)
PermissionError: [Errno 1] failed to run command: ethtool -s eth5 autoneg on
returned:
exit code: 1
noteworthy:
cmd 'ethtool --pause eth5 autoneg on tx on rx on'
returned (out):
returned (err):
netlink error: Invalid argument
cmd 'ethtool -K eth5 ufo off'
returned (out):
returned (err):
Could not change any device features
cmd 'ethtool -s eth5 autoneg on'
returned (out):
returned (err):
netlink error: link settings update failed
[[interfaces ethernet eth5]] failed
Commit failed
najib@vyos# exit
Thanks.
