I receive a COMMIT FAILED when committing … I just wonder why …
Interface eth5 … configured this way
[edit interfaces ethernet eth5]
vyos@VYOS# show |commands
set disable-flow-control
set duplex ‘full’
set hw-id ‘33:44:55:66:77:88’
set mtu ‘9192’
set speed ‘10000’
set vif-s 100 mtu ‘9192’
set vif-s 100 protocol ‘802.1q’
set vif-s 100 vif-c 3996
set vif-s 100 vif-c 3997
set vif-s 100 vif-c 3998
set vif-s 100 vif-c 3999
set vif-s 201 mtu ‘9192’
set vif-s 201 protocol ‘802.1q’
set vif-s 201 vif-c 3980
set vif-s 201 vif-c 3981
set vif-s 201 vif-c 3982
set vif-s 201 vif-c 3983
set vif-s 201 vif-c 3984
set vif-s 201 vif-c 3985
set vif-s 201 vif-c 3986
set vif-s 201 vif-c 3988
set vif-s 201 vif-c 3989
set vif-s 201 vif-c 3992
set vif-s 201 vif-c 3993
set vif-s 201 vif-c 3994
set vif-s 201 vif-c 3995
set vif-s 201 vif-c 3996
set vif-s 201 vif-c 3998
set vif-s 201 vif-c 3999
set vif-s 203 mtu ‘9192’
set vif-s 203 protocol ‘802.1q’
set vif-s 203 vif-c 3900
set vif-s 203 vif-c 3901
set vif-s 203 vif-c 3902
set vif-s 203 vif-c 3903
set vif-s 203 vif-c 3904
set vif-s 203 vif-c 3905
… etc. etc.
I need to delete all vif-c items of the vif-s 201 so , just before committing I have this “show” result
vif-s 201 {
- vif-c 3980 {
- vif-c 3981 {
- vif-c 3982 {
- vif-c 3983 {
- vif-c 3984 {
- vif-c 3985 {
- vif-c 3986 {
- vif-c 3988 {
- vif-c 3989 {
- vif-c 3992 {
- vif-c 3993 {
- vif-c 3994 {
- vif-c 3995 {
- vif-c 3996 {
- vif-c 3998 {
- vif-c 3999 {
but … if I do “commit” … FAIL !
With this long error
https://support.vyos.io/ - Make sure you are running the latest version of VyOS available at:
VyOS Community - Consult the community forum to see how to handle this issue:
https://forum.vyos.io - Join us on Slack where our users exchange help and advice:
https://vyos.slack.com
business policy requires it) - and include all the information presented below
Report time: 2023-05-04 14:48:31
Image version: VyOS 1.3.2
Release train: equuleus
Built by: derago@gmail.com
Built on: Mon 19 Sep 2022 08:13 UTC
Build UUID: de150757-9a82-4634-a288-a3ae2f261827
Build commit ID: 3fda91501f31b8
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: HP
Hardware model: ProLiant DL360e Gen8
File “/usr/libexec/vyos/conf_mode/interfaces-ethernet.py”, line 165, in
apply(c)
File “/usr/libexec/vyos/conf_mode/interfaces-ethernet.py”, line 154, in apply
e.update(ethernet)
File “/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py”, line 357, in update
super().update(config)
File “/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py”, line 1470, in update
VLANIf(vif_c_ifname).remove()
File “/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py”, line 318, in init
self._create()
File “/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py”, line 1560, in _create
self._cmd(cmd.format(**self.config))
KeyError: ‘source_interface’
[[interfaces ethernet eth5]] failed
Commit failed
Archiving config…
ftp://172.20.21.84/Junos [edit interfaces ethernet eth5 vif-s 201]
a.montano@VYOS-BT-1# discard
Changes have been discarded
Can anyone figure out where the problem is?
