I am having issues after upgraded OS from VyOS 1.0.5 to VyOS 1.1.3
After upgrade to VyOS 1.1.3, I cannot do any modification and commit. As soon as I commit, I lost connectivity to vyatta and I had to reboot it. It come up fine with old configuration file ( config.boot )
Here are some messages I see when I enter in to config mode
vyatta@dwvyatta:~$ config
fuse: failed to open /dev/fuse: Permission denied
vyatta@dwvyatta# exit
fusermount: entry for /opt/vyatta/config/tmp/new_config_3428 not found in /etc/mtab
exit
vyatta@dwvyatta:~$
vyatta@dwvyatta:~$ show version
Version: VyOS 1.1.3
Description: VyOS 1.1.3 (helium)
Copyright: 2015 VyOS maintainers and contributors
Built by: [email protected]
Built on: Wed Jan 28 14:11:52 UTC 2015
Build ID: 1501281411-ed1724a
System type: x86 64-bit
Boot via: image
Hypervisor: Xen hvm
Uptime: 07:59:33 up 0 min, 1 user, load average: 0.19, 0.05, 0.02
vyatta@dwvyatta:~$
vyatta@dwvyatta:~$ show system image
The system currently has the following image(s) installed:
Was this an image based of system install that you were upgrading from? I know you said the VyOS install was image based, I just wanted to check that it was an image based install through the whole upgrade. If you can let me know, then I can duplicate the process you’re going through and track down what’s causing it.
Recently I tried Upgrade from vyatta Core >> VyOS 1.1.3 >> VyOS 1.1.5 and It did not show that issues. Could be problem with VyOS 1.0.5 ( I would need to re-test again )
