Commiting exchange of tunnel remote ip does not resolve dependencys (fail)
when my ansible playbook writes a new configuration with order changes in tunnel naming vyos cant apply them properly because It does not resolve the dependencies/arrangement correctly.
As you can see, it attempts to exchange the remote IP of two tunnels simultaneously, which VYOS cannot handle. the problem is that it does not take into account that you cant have 2x tunnel interfaces with same remote and source combination at the same time, even for quick time. for types gre/gretap…
vyos@vyos# comp
[interfaces tunnel]
+ tun669001 {
+     encapsulation "gretap"
+     mtu "1462"
+     remote "66.66.66.1"
+     source-address "1.1.1.1"
+ tun669002 {
+     mtu "1462"
+     remote "66.66.66.2"
vyos@vyos# commit
vyos@vyos# set interfaces tunnel tun669001 remote '66.66.66.2'
vyos@vyos# set interfaces tunnel tun669002 remote '66.66.66.1'
vyos@vyos# commit
[ interfaces tunnel tun669001 ]
  File "/usr/libexec/vyos/services/vyos-configd", line 144, in run_script
    script.apply(c)
  File "/usr/libexec/vyos//conf_mode/interfaces_tunnel.py", line 217, in apply
    tun = TunnelIf(**tunnel)
  File "/usr/lib/python3/dist-packages/vyos/ifconfig/tunnel.py", line 103, in __init__
    super().__init__(ifname, **kargs)
  File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 349, in __init__
    self._create()
  File "/usr/lib/python3/dist-packages/vyos/ifconfig/tunnel.py", line 128, in _create
    self._cmd(cmd.format(**self.config))
  File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 64, in _cmd
    return cmd(command, self.debug, env=env)
  File "/usr/lib/python3/dist-packages/vyos/utils/process.py", line 155, in cmd
    raise OSError(code, feedback)
FileNotFoundError: [Errno 2] failed to run command: ip link add name tun669001 type gretap local 1.1.1.1 remote 66.66.66.2 tos inherit ttl 64
returned:
exit code: 2
[[interfaces tunnel tun669001]] failed
Commit failed
its a bit annoying. i can with some effort write some sort of workaround, but i think this isnt a solution. i think vyos should handle such cases, correct me if im wrong, but thats what this is all for, right?
i confirmed this issue in latest rolling Version: VyOS 2026.01.24-0021-rolling.
and also in 2025-Q2 Stream.
Thanks!
@virtualized-human Could you open a bug report on the our bug tracker? https://vyos.dev/
With minimal set of commands to reproduce,
Thanks
yes,
im currently waiting for activation since some days. then i will do it.
Your account has been created, but needs to be approved by an administrator. You’ll receive an email once your account is approved.
