Config review
Hello all,
I’ve migrate an old version of vyatta (6.5) to the latest VyOS.
Since many months, we have a probleme with my bgp peer.
I reviewed the conf but i dont find where the problem is.
I’ve my AS and have 2 bgp peer with 2 operators.
If someone can help me to understand …
How i can correctly write regex field in as-path-list.
After many search, i find this way to write them “^xxxx_” but i’m not sure that really works fine.
But, in this case, how can i write the regex for my second peer ?
i can’t use the same way because the 2nd peer isn’t my favorite out. -
How i can prioritiez/force all the out traffic to my favorite AS.
Same reflexion as the first question, is the as-path-list really used to make out priority. -
How i can prioritize/force a part of specifique traffic to an AS
I’ve 2 class of ip adress with 2 sites. How can i dispatch one class on one site and the other and the second site.
Actually, the both is on the same router
I can copy/past my conf if i can help you
